1998 GL1500 SE electrical issue - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 03-13-2010, 12:33 PM Thread Starter
O.K. here's the deal: I have a 1998 GL1500 SE with some electrical issues, the bike starts and runs decent, but I have no dash lights, fuel gauge, temp. gauge. The reverse light does not light up and sometimes doesn't work at all. I have a manual, test light and multimeter. PLEASE HELP..... Thanks, Lon
1998 GL1500 SE
1971 Norton Commando
2005 CRF150F
1999 Triumph Trophy 900
1957 harley Davidson Panhead
1979 Triumph 750 Bonneville
powersport15 is offline
post #2 of 13 (permalink) Old 03-13-2010, 12:56 PM
L8ndeb's Avatar
Year: 1995
Model: Interstate
Send a message via Yahoo to L8ndeb
I would for starters:
Check fuses 1, 2, 3, 7, 8, 9, 10, 12, and 13. Check relay #3.
Leyton at Reno
1995 GL1500I
L8ndeb is offline
post #3 of 13 (permalink) Old 03-13-2010, 01:15 PM
divie1066's Avatar
Hello and welcome powersport15 Pull up a chair and join in
Some real nice folks on here and there knowledge is endless
I can't help you but I do know is one of the lads will be along soon
to help you out
Life is good, well almost!!!!
A stranger is friend you have yet to meet.
divie1066 is offline
post #4 of 13 (permalink) Old 03-13-2010, 07:47 PM Thread Starter
All fuses are good, although I have no power on Fuse #7, I swapped relay #3 and nothing changed. The bike starts and runs. It does seem to be running hot, the fans are cycling. but the temp gauge is inop. so its hard to tell. Thanks...
1998 GL1500 SE
2005 CRF150F
post #5 of 13 (permalink) Old 03-13-2010, 08:05 PM
You only have power on fuse #7 when the switch is in the park position, nothing to worry about there. If fuse #8 is good pull #3 relay and check for power to 1 terminal all the time, 2 terminals when the ignition is on. 1 terminal should be grounded and the other goes to the lights and gauges etc, (will also show continuity to ground).
post #6 of 13 (permalink) Old 03-13-2010, 08:12 PM Thread Starter
Thanks, I'll check asap...
1998 GL1500 SE
2005 CRF150F
post #7 of 13 (permalink) Old 03-13-2010, 08:12 PM
L8ndeb's Avatar
Year: 1995
Model: Interstate
Hi dave,
Beat me to the post. I will add, if you have no power in the conditions Dave described, I would pull the fuse/relay box to see the condition of the connections at the back of the box.
Leyton at Reno
1995 GL1500I
L8ndeb is offline
post #8 of 13 (permalink) Old 03-13-2010, 08:20 PM Thread Starter
I have pulled the relay/fuse box and everything looks fine and no burnt terminals front or back..
1998 GL1500 SE
2005 CRF150F
post #9 of 13 (permalink) Old 03-13-2010, 08:21 PM
L8ndeb wrote:
Hi dave,
Ditto that, I just today worked on Aspectone's bike and that seemed to be the problem with the brake light relay but once I got the fuse box out and the back cover off it started working and could not make it quit.
post #10 of 13 (permalink) Old 03-13-2010, 08:23 PM Thread Starter
I would have to say this is a great forum, I wish I would have found it sooner! Thanks alot guys and I'll let you know what I find with the #3 relay..
1998 GL1500 SE
2005 CRF150F
GL1200 carb issue, or electrical issue ole wing Goldwing Technical Forum 22 09-25-2012 05:16 AM
Electrical issue - GL1500 951Indy Goldwing Technical Forum 3 09-13-2010 04:30 PM
1996 GL1500 electrical issue Al K Goldwing Technical Forum 3 06-05-2009 12:28 AM
Gl1500 electrical issue PaWinger Goldwing Technical Forum 3 04-17-2009 09:46 PM
Electrical Issue GL1500 Aspencade mdgulick Goldwing Technical Forum 1 04-07-2009 09:42 PM
