GL1200 FUEL PUMP RELAY - Page 3 - Steve Saunders Goldwing Forums
post #21 of 22 (permalink) Old 03-19-2011, 09:55 AM
I'm restoring a 1984 GL1200i and am trying to get it started. I had the tank out and cleaned. The fuel pump checks out OK but I can't get it to pump. When I push the start button I don't hear the pump making any noise and don't feel any vibration from the pump. Does this mean the relay is bad and I should replace it?
thomasthomas is offline
post #22 of 22 (permalink) Old 03-19-2011, 01:49 PM
RoyP's Avatar
Thomas, look right by the gas cap thats where the fuel pump is plugged in. pull that plug apart one wire is hot one is cold use your test light to see if you have 12 volt coming from the bike to the fuel pump. should light up when cranking engine with starter button, or when bike is running only. no voltage when not running
Roy
1974 Honda 500 four
1978 GS750E
1965 Triumph 500 tiger compitition
1984 Aspencade Gl1200
RoyP is offline
Fuel Pump Relay, GL1200 dirt devil Goldwing Technical Forum 4 11-14-2011 10:00 AM
GL1200 fuel pump relay lyleapgmc Goldwing Technical Forum 4 06-06-2010 06:47 PM
GL1200 fuel pump RELAY test bobg Goldwing Technical Forum 11 03-28-2010 04:57 PM
fuel pump relay marc Goldwing Technical Forum 2 04-08-2009 09:45 PM
FUEL PUMP RELAY GL1200 mikecutter Goldwing Technical Forum 1 10-24-2008 09:32 AM
