85 1200 Aspencade motor removal - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 04-02-2010, 09:07 AM Thread Starter
The Handyman's Avatar
Year: 1994
Model: GL 1500 SE
Am doing the stator change in my 1200 On the front of the engine is the wires from the pulse gen and coming up off the bottom of the engine is another set (I believe that set is the shift sensor, not sure tho) These sets go way up under the dash and I cannot find a connector in them. Would it be advisable to cut them then re solder them when I do reinstall
or is there something that I am missing? Also my Clymer book says to remove timing belts and gears. Is it necessary or can I leave them on till it is out? Am worried about it getting out of time when we pull the motor out of the bike. I have new belts to go on her.
Thank you in advance for your help
Ben
The Handyman
The Handyman is offline
post #2 of 14 (permalink) Old 04-02-2010, 10:34 AM
The Irish Crew
FitzAl's Avatar
Model: GL1100 Interstate
The engine will come out easier with the belt covers removed and even easier with the right side cam pulley off.
Alan Fitzpatrick.
FitzAl is offline
post #3 of 14 (permalink) Old 04-02-2010, 10:37 AM
nsjoe's Avatar
Model: GL1800A
The Pulse Generators definetley have a plug. Look for it at the spark unit.
Joe
Darksider #493
Former bikes:
\'80 CB750 Custom
\'86 GL1200 Interstate
nsjoe is offline
post #4 of 14 (permalink) Old 04-02-2010, 04:27 PM
Guru
Hatchetman's Avatar
Leave the engine in the bike & install the "poor boy" kit! Better power, easier repairing in the future!
Hatchetman is offline
post #5 of 14 (permalink) Old 04-02-2010, 07:45 PM Thread Starter
Year: 1994
Model: GL 1500 SE
Never had any luck with connectors close. Removed the pulse gen's The other set of wires have to be the gear indicator. Traced it up to the plug by the left pocket. Wound up snipping it. Couldn't get it fed back out since it was under an Air or brake line She is on the rebuild now. If this stator gives out on me I will DEFINITELY be doing a poor boy repair like Hatchetman suggested
Thank you all for your help
Ben
The Handyman
post #6 of 14 (permalink) Old 04-04-2010, 10:42 PM Thread Starter
Year: 1994
Model: GL 1500 SE
She is all back together again. Too late when I finished tonight so will be going out for a test ride tomorrow Looks like the new stator starts charging at about 800-900 RPM Wont tackle that project again. If she goes out again it will be a poorboy fix.
Ben
The Handyman
post #7 of 14 (permalink) Old 04-05-2010, 12:02 AM
William_86's Avatar
Model: GL1500 Aspencade
I been there a month ago. on a friends bike, it was a pita had to remove coils and work them out. i routed them differently so it would be easier to remove next time :P
William_86 is offline
post #8 of 14 (permalink) Old 04-05-2010, 12:26 AM
Did you usean OEM or aftermarket stator?
post #9 of 14 (permalink) Old 04-05-2010, 09:30 AM Thread Starter
Year: 1994
Model: GL 1500 SE
I got my stator from RM stator on 14/07/09. cost was $100 Cdn and they paid shipping Reason took so long to get it in was I rode the bike all summer and wound up working away from home in winter
Ben
The Handyman
post #10 of 14 (permalink) Old 04-05-2010, 01:47 PM
whats this kit. im having the same problem with my aspencade. i dont want to pull this engine!lol
stonley99 is offline
87 Aspencade gl 1200 rear wheel removal redz90 Goldwing Technical Forum 19 08-25-2009 11:49 AM
motor removal gl1000 '77 2Dahorizon Goldwing Technical Forum 8 07-19-2009 06:05 AM
85 goldwing aspencade 1200 starter removal farnold Goldwing Technical Forum 2 02-15-2009 09:27 PM
starter motor removal sabel Goldwing Technical Forum 4 03-01-2008 05:05 PM
GL1000 Stator Removal without motor removal? bob007 Goldwing Technical Forum 4 06-18-2007 07:26 PM
