Not sure if a 1500 Wing has a diode in the start system, but many 70's and 80's Honda's did. clutch has to pulled to start, even in neutral, if the diode has failed. Doesn't sound like that fits your problem but diodes can create some hard to find troubles, just might be something to check
Here's hpw mine works. The side stand has to be up and the clutch lever in. If I stall at the light... With the key on and the side stand up, I have to let the clutch all the way out and pull it back in to start the bike while in gear.
Letting the clutch out "resets" something.
73.6K members
