83 GL1100A Rear Shock Rebuild Problem - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 04-10-2010, 01:37 PM Thread Starter
I just got one of the shocks taken apart. The end opposite of the seal popped out exposing the 2 "0" rings on the top piece and allowing me to view into the top part of the shock. An oily, dissolving mess that once was some kind of rubber buffer between the damper case guide(?) and the top of the cylinder was in that space. The "O" rings, buffer, and top piece are not parts depicted in the diagrams of the shock. Anyone have info on where to get a replacement buffer piece or what to use as a replacement? After seeing this, I wonder how many others have not disassembled their shocks to this extreme when changing the seals and overlooked this problem.
n4fv is offline
post #2 of 6 (permalink) Old 04-10-2010, 02:11 PM
brianinmaine's Avatar
Year: 1980, 1987
Make: Goldwing
Model: 1980 Standard, 1987 Aspencade
some people have changed springs to progressive on the rear, requiring the dis-assembly of the top portion. It sounds to me like part of the top half came apart? I have rebuilt mine, (a couple years ago), and just put it back together without that bumper, I think. There are some pictorial writeups if you do a search.
Welcome to this forum, it's a lot of fun!
Brian Trauger
1980 Standard : Pacifico fairing : Vetter trunk.
1987 Aspencade : Fully dressed.
brianinmaine is offline
post #3 of 6 (permalink) Old 04-10-2010, 03:57 PM Thread Starter
What concerns me is I am a big guy and momma ain't so little herself. Metal banging against metal would not be a good thing.
n4fv is offline
post #4 of 6 (permalink) Old 04-10-2010, 04:16 PM
JBz
JBz's Avatar
if you just wanted to change theoil seal you went overboard. The seal on the bottom is usually what leaks .The top 2 o rings on the shock mount you might just have to measure them as ive never seem them listed sepately. jb
JBz is offline
post #5 of 6 (permalink) Old 04-10-2010, 07:04 PM
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
That bushing is necessary if you use Progressive springs.
P.G.R. Member ID: 88374
Broke Winger is offline
post #6 of 6 (permalink) Old 04-12-2010, 09:59 AM
icechopper's Avatar
Year: 86 GL1200I
I don't know if you've seen this post. Check out Gambler's post with pictures for great information.
Steve Saunders Goldwing Forums > Steve Saunders Goldwing Forums > Reference and FAQ Forum > shock rebuild, gl1200
icechopper is offline
Rear shock rebuild GL1100 oharaLTD Goldwing Technical Forum 14 08-16-2011 08:32 PM
Rear shock bushings 82 GL1100A Olphart48 Goldwing Technical Forum 4 11-09-2008 09:01 PM
rear shock rebuild kevin Goldwing Technical Forum 2 08-12-2007 06:52 AM
rear shock rebuild? creekwalker Goldwing Technical Forum 9 07-11-2007 04:30 PM
rear shock rebuild DoDefoort Goldwing Technical Forum 5 04-17-2007 09:08 PM
