Neutral safety switch on 82 interstate - Steve Saunders Goldwing Forums
post #1 of 20 (permalink) Old 04-24-2010, 07:40 PM Thread Starter
michealu615's Avatar
Where is the neutral safety switch on an 82 interstate? The light doesnt come on and you have to pull the clutch in to start it. Any ideas? Thanks Micheal
Why aint we got the Wings in the Wind!!!!
michealu615 is offline
post #2 of 20 (permalink) Old 04-24-2010, 09:56 PM
The switch is on the lower right of the engine case behind the frame rail, hard to get to. Check the wire to the switch.
post #3 of 20 (permalink) Old 04-24-2010, 11:54 PM
Nope, the neutral switch on the '82 is under the front cover not on the front side by the frame like the earlier models. The lead from the switch should show a ground when checked with an ohmmeter when the transmission is in neutral and will show infinite ohms (open circuit) when any gear is selected. But firstcheck the neutral lamp bulb, don't laugh and don't ask how I know.
post #4 of 20 (permalink) Old 04-25-2010, 12:18 AM
William_86's Avatar
Model: GL1500 Aspencade
a faulty bulb will cause the engine not to start in neutral?, just wondering.
William_86 is offline
post #5 of 20 (permalink) Old 04-25-2010, 12:48 AM
brianinmaine's Avatar
Year: 1980, 1987
Make: Goldwing
Model: 1980 Standard, 1987 Aspencade
yeah a bad bulb is 1 of 2 paths for ground, the other being the clutch switch on the lever:
***WOW that was a really dumb thing to say! the bulb is obviously not a path for ground, it's through the switch!***
(I think the fuse in line there is the 3rd from the left in the fuse box)
Brian Trauger
1980 Standard : Pacifico fairing : Vetter trunk.
1987 Aspencade : Fully dressed.
brianinmaine is offline
post #6 of 20 (permalink) Old 04-25-2010, 01:21 AM
William_86's Avatar
for what i see on the diagram. even if the bulb was shot, the solenoid would still be getting grounded by the neutral switch. the neutral switch, positive end is connected to the ignition and the positive lead is not related to the star switch as it appears on the diagram. it just shows its connected to the ignition switch power just like the solenoid
Michael, have you removed the front engine cover lately, like for an water pump service?
post #7 of 20 (permalink) Old 04-25-2010, 05:56 AM
My bad, I was thinking of my 82 (sort of) with an 80 model engine.
The bulb should not cause the solenoid ground circuit to be open.
post #8 of 20 (permalink) Old 04-25-2010, 06:06 AM Thread Starter
I have put timing belts on it not a water pump i am working on it for a friend. Where is the wire i need to check. On that model do you have to have the clutch pulled in even to start in nuetral? On my 83 you dont have to pull it in in nuetral.
post #9 of 20 (permalink) Old 04-25-2010, 06:31 AM
daveman's Avatar
Hey Michael, the neutral switch wire passes thru the front cover. If your friend had that cover off for a water pump change (or any other reason), he may not have lined the switch back up properly....the switch (mounted inside of the front cover) uses a pin that fits into a corresponding holder when you put the cover back on after removal, and needs to be lined up properly (don't ask me how I know that). By any chance does the light come on at a weird time when cycling through the gears on the road?
Good luck!
1983 GL1100 (aka "The Beast" )
2003 750 ACE
1983 V45 Magna (...zoom!) Sold
1979 CB750 Sold
daveman is offline
post #10 of 20 (permalink) Old 04-25-2010, 06:34 AM
The wire runs down the front of the engine behind the inner timing cover.
It should start in neutral without pulling the clutch.
Neutral safety switch GL1500 AlbertCo wing Goldwing Technical Forum 8 07-20-2015 03:25 PM
GL1100 micro-switch for jack - safety switch haimayelet Goldwing Technical Forum 6 09-04-2012 05:13 PM
1993 gl1500I neutral safety switch leondrew Goldwing Technical Forum 6 06-04-2012 02:03 PM
Neutral safety switch removal, GL1000 FADM Stern GNSF Goldwing Technical Forum 5 10-20-2011 05:56 PM
Neutral safety switch Rod Goldwing Technical Forum 6 08-24-2005 09:56 AM
