Overdrive light don't work GL1500 - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 04-29-2010, 11:50 PM Thread Starter
I have a 1992 gl1500 SEthe over drive light doesn't work when i put it in top gear it's shifting into OD & works fine but no OD light so i can't use my cruise all my lights work when i turn the key on so it's not a bulbi ordered a repair manual hopefuly i can fix it asap she's my baby it's mint so that realy bugs me if anybody has any ideas please let me know THANKSGILBERT1244
gilbert1244 is offline
post #2 of 6 (permalink) Old 04-30-2010, 04:56 AM
nsjoe's Avatar
Model: GL1800A
welcome to the forum gilbert. That's a pretty bike. Someone will be along shortly that will have a better idea than I.
Joe
Darksider #493
Former bikes:
\'80 CB750 Custom
\'86 GL1200 Interstate
nsjoe is offline
post #3 of 6 (permalink) Old 04-30-2010, 05:14 AM
Most likely the problem is the gear position switch on the transmission.
post #4 of 6 (permalink) Old 04-30-2010, 05:22 AM
Monkey with a Football
Rudy's Avatar
You may need to clean the C135 connector up under the right lower faring, above the right cooling fan shroud. It is the forward-most lower connector on the bracket. It has a black housing and is 6 pin.
Rudy
wasn't too much fun”
Rudy is offline
post #5 of 6 (permalink) Old 04-30-2010, 05:34 AM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
The Cruise Control will work in either 4th gear or 5th(OD). Could be your gear position switch.
Here's how you check to see if it is shot. Check it 1st and then get back to us.
Dusty
- just another Rider
Dusty Boots is offline
post #6 of 6 (permalink) Old 04-30-2010, 08:19 AM Thread Starter
thanks i'll give it a try & let you know if it worked
GL1500 OverDrive Light/Low Fuel light blkeatts Goldwing Technical Forum 12 05-24-2013 02:01 PM
overdrive light hodeman Goldwing Technical Forum 2 08-14-2010 03:36 PM
GL1500 overdrive & reverse Bluewings Goldwing Technical Forum 1 06-01-2009 11:28 AM
Overdrive on 96 GL1500 SE Goldwing Technical Forum 7 08-16-2008 04:38 AM
Overdrive Light exavid Goldwing Technical Forum 11 02-23-2005 01:39 AM
