Found GL1500 coolant leak I think? - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 05-01-2010, 06:08 PM Thread Starter
Anyways tore radiators and such off getting mad at leak. Seems clamp came a little loose and up rad hose slid up and clamp down, only about 1/2 still holding loosely. So ? now how long are these hoses good for? Thinking I should replace maybe since it's all torn apart. Any thoughts? Also any other hoses I should think about replacing. I'm assuming everything original as records do not indicate otherwise. It's a gl1500 "89" if that helps thank you
h2smokin is offline
post #2 of 6 (permalink) Old 05-01-2010, 06:13 PM
rgbeard's Avatar
Replace a 20-year old coolant hose - heck yeah!!!
If you've got it this far apart - why not.
BikeBandit.com is a good resource that is somewhat close to you (San Diego) for prompt shipping.
My name is Rusty. I'm an enthusiast of things that ride, drive and fly.
IBA: 63413
rgbeard is offline
post #3 of 6 (permalink) Old 05-01-2010, 06:32 PM Thread Starter
I'm gonna poke around tomorrow on it looking at things closer. The little hose connecting the rads at the top came apart as well. Hopefully I can get a heads up on other things to look for as well
h2smokin is offline
post #4 of 6 (permalink) Old 05-01-2010, 07:21 PM
wda-83wing's Avatar
Model: 83 GL 1100 I
any hose that old should be looked at very closly , in cluding the vacum lines , and there is a bunch.
wda-83wing is offline
post #5 of 6 (permalink) Old 05-01-2010, 08:10 PM Thread Starter
Is there a certain size vacuum line I can get at the auto supple if needed? I know if I start looking I'll find other things which can be a pain. I'm planning on my 1st long trip on the bike in june for 2/3k and would rather be safe. Thanks again for any info
h2smokin is offline
post #6 of 6 (permalink) Old 05-01-2010, 08:19 PM
I was told that a 1/4" vacuum line is close for the larger line.. A tad bit large maybe for the larger lines. The smaller ones, I don't know.
GL1500 Coolant Leak BrianLegan Goldwing Technical Forum 22 01-25-2015 08:24 PM
GL1500 Coolant Leak mike1950 Goldwing Technical Forum 6 06-12-2012 07:10 AM
GL1500 Coolant Leak mike1950 Goldwing Technical Forum 11 01-18-2012 03:10 PM
gl1500 coolant leak Derek Goldwing Technical Forum 7 04-11-2009 11:53 AM
GL1500 Coolant leak midwing Goldwing Technical Forum 7 02-22-2009 07:48 PM
