GL1200 Front Wheel Bearing Removal - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 05-15-2010, 06:04 PM Thread Starter
Year: 1985
Make: GL1200
Model: Aspencade
I'm trying to change the front bearings on my 85 GL1200a. I've searched this forum, and tried a few things to get the old bearings out. They are in tight!
The distance collar will only move about 1 mm to the side, and my drift punch keeps slipping on the narrow purchase it gets, so that hasn't worked.
I got some 5/8" heavy duty concrete anchors, and ground them down a bit, and got one jammed into the inner race good and snug several times, and pounded it out - but it keeps slipping out.
I saw the split bolt and wedge thing, but can't imagine it's any stronger than this concrete expansion bolt.
Any other ideas? (I saw one guy post that you just hammer on the inner race of thebearing on the other side, and the inner race and distance collar will push theother bearing out. That doesn't make sense to me - the inner races don't seem to move laterally with the bearings in place. ) But if it works, I'll try it. Just don't want to damage my wheel.
I'm running out of options - might have to take it to a shop. Do motorcycle mechanics have some magic tool for this?
Frank
Frank vH is offline
post #2 of 10 (permalink) Old 05-15-2010, 07:02 PM
Year: 1990
Model: Aspy Roadsmith Trike (converted 2014)
I'm very fortunate to have a neighbor with an electric hydralyic (sp)arbor press.
Takes about 10 minutes to press out the old bearings & seals,then press in the new ones.
Scootertrash is offline
post #3 of 10 (permalink) Old 05-15-2010, 08:36 PM
Senior Something
ebanjo's Avatar
Year: 1979
Model: GL 1000
Found this link for a DIY bearing removal tool. It was for a 1500 but could be adapted for your 1200.
http://home.comcast.net/~rkekeis/WHE...INGREMOVER.htm
Happy Trails
My pic's
ebanjo is offline
post #4 of 10 (permalink) Old 05-15-2010, 09:01 PM
The split bolt usually works but if the concrete anchor won't hold I doubt the split bolt will either. I assume you've tried on both bearings? You might try tapping the bearing down to make sure it's flat in it's recess and try again, if they get cocked they aren't going to move at all. You might try using a split bolt if you can find one the same diameter as the axle without any threads in the working area. Grind the end to a sharp flat edged end. Then put it through the wheel and tap the wedge in to the bolt but make sure the end of the bolt is above the bearing slightly. With the wedge driven into the split tap the bolt down until it contacts the bearing and drive the wedge as tight as you can. The idea is to get the split end of the bolt to catch the joint between the internal spacer and the edge of the bearing. They both have a bit of chamfer so it should be possible to lock the split above the bearing a bit. I don't know at the moment whether the concrete anchore has an edge that can catch the groove the joint makes or not because I've only used a split rod similar to a split bolt to do the job.
post #5 of 10 (permalink) Old 05-15-2010, 10:01 PM
millisec's Avatar
I watched my Honda mech change mine....a little heat from a propane torch around the hub..............and POP! out they came
Just because you have announced your arrival......
Doesn\'t mean you are there!
millisec is offline
post #6 of 10 (permalink) Old 05-16-2010, 06:35 AM
RayandTracy's Avatar
http://s382.photobucket.com/albums/o...ol%20homemade/
this is how I do mine, try using an old small punch, you'll notice I cut a cross so the punch pushes all four sides out at the same time. I've had some tough ones but they all have came out with the right sized hammer
RayandTracy is offline
post #7 of 10 (permalink) Old 05-16-2010, 09:00 PM Thread Starter
Year: 1985
Make: GL1200
Model: Aspencade
Thanks guys. I'm gonna try the heat first, and if that doesn't work - one of the other split bolt ideas. This forum is the best!!
I'll let you know how it goes.
Frank
Frank vH is offline
post #8 of 10 (permalink) Old 05-16-2010, 09:10 PM
rgbeard's Avatar
Just be careful - I had the bearings pretty hard-frozen in mine, and one of the fronts had come all apart in my hands, leaving the outer shell in the wheel with no way to get it out.
Sometimes - especially at the price of a replacement wheel, it's time to get a shop involved.
My name is Rusty. I'm an enthusiast of things that ride, drive and fly.
IBA: 63413
rgbeard is offline
post #9 of 10 (permalink) Old 05-18-2010, 06:41 PM Thread Starter
Year: 1985
Make: GL1200
Model: Aspencade
Guys: thanks again. I got the old bearings out. Used the concrete expansion bolt, and some heat from a propane torch. That got it to move ever so slightly, and then I was able to drive it out with a drift punch, because the distance collar loosened up.
Rode it today, then discovered a nail in my rear tire! Now I need to deal with that!
Frank vH is offline
post #10 of 10 (permalink) Old 05-18-2010, 08:51 PM
Ain't it the truth? You have the wheel off to fix something then put it back on only to find a nail in it that means it has to come off again.Exasperatin' to the Max!
But better than going flat on the road.
82 Gl wheel bearing removal t18skyguy Goldwing Technical Forum 5 08-20-2010 01:22 PM
Front wheel removal on 85 GL1200 aspy. HondaOW Goldwing Technical Forum 3 07-21-2010 10:38 PM
Front wheel bearing removal on GL1200 Xtracho Goldwing Technical Forum 10 05-22-2010 10:43 AM
84 GL1200 Front wheel removal pjfsail Goldwing Technical Forum 13 07-08-2008 06:20 PM
1984 GL1200 front wheel removal! BHall235 Goldwing Technical Forum 2 10-07-2004 05:37 PM
