Front wheel bearing removal on GL1200 - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 05-21-2010, 03:14 PM Thread Starter
Xtracho's Avatar
Location: Panama City Beach, FL and Rio de Janeiro, Brazil
Model: '84 Aspencade
So I have my front wheel off and remove the bearing from the right side using the threaded bolt and screwdriver technique in the goldwingdocs.com tutorial. The right side comes out...not problem. But... the left side is another issue.
When I tapped on the bearing it disintegrated. The front of the race came out and all the bearings as well. What I'm left with is the back side of the bearing race still stuck in the wheel hub and I cannot figure out how I'm gonna get the thing out.
I'm fixing to go outside and put some heat on it to see if somehow someway I can loosen it up and pry that thing, tap that thing, or somehow get it out. Problem is there isn't much of a lip or anywhere to get some leverage.
Anyone have any ideas, suggestions, similar experiences that they remedied somehow?
Thanks!
Mark
1984 GL 1200 Aspencade
To live you must be willing to die - Amir Vahedi
My father gets smarter everyday that he's gone.
I worried that I had no shoes until I saw a man that had no feet.
Xtracho is offline
post #2 of 11 (permalink) Old 05-21-2010, 03:29 PM
Mark,
Do you have access to freon or liquid helium or CO2 in a can?
Heating up the hub and freezing the bearing race should allow it to be slipped out.
Same thing happened to my son's bike while I was riding on it a few years back. I forget how my mechanic said he got it out, but I think it was as I described above.
Even at that, you need a hammer and punch to make it come out.
post #3 of 11 (permalink) Old 05-21-2010, 05:34 PM
Heat should do it, heat the hub until it's too hot to touch and then hit the race with some ice. The aluminum hub should expand more than the steel race and loosen up a bit, by cooling the race with ice it will shrink faster than the aluminum hub due to the aluminum's greater mass.
post #4 of 11 (permalink) Old 05-21-2010, 05:37 PM Thread Starter
Xtracho's Avatar
Would a propane torch generate enough heat? I talked to my shop and the mechanic said he would use a Dremel cutting wheel, cut the race in several spots, then pry the remaining parts of the race out of the hub.
Here is what I have on the left side of the wheel....
As you can see...all I have is the back part of the race. The rest of the bearing fell apart and left me with this.
Mark
Xtracho is offline
post #5 of 11 (permalink) Old 05-21-2010, 05:47 PM
i think Paul may have the best solution for you.
Dremel tool and a very small diamond cutting disc/wheel.
Cut it in quarter or third size chunks and pick it out.
But, i would try that small punch you have first. from the back side of the wheel and tap the race a bit at a time about a 1/2 inch apart points.
Patience. I know you have the punch, because I borrowed it to make that hole in my bike's filler neck.
post #6 of 11 (permalink) Old 05-21-2010, 05:48 PM
Same thing happened to mine , I took it to a shop and he found a round tool just a little smaller to put on it and punch it out with a hammer . Paid him 10.00
picasso is offline
post #7 of 11 (permalink) Old 05-22-2010, 07:38 AM
rgbeard's Avatar
I'd err on the side of caution and have a machinist do this - a new wheel will cost $$$.
I was in *exactly* this same position myself about a year ago and did the machine-shop route. Only after hacking at it with a Dremel.
The machinist at the shop said I should be glad I stopped when I did.
My name is Rusty. I'm an enthusiast of things that ride, drive and fly.
IBA: 63413
rgbeard is offline
post #8 of 11 (permalink) Old 05-22-2010, 08:51 AM Thread Starter
Xtracho's Avatar
Interesting Rusty. What did the machinist do to get it out and what was the cost?
Mark
Xtracho is offline
post #9 of 11 (permalink) Old 05-22-2010, 08:58 AM
Xtracho, if you have a Harbor Frieght close by they have a bearing puller for about $17.00. Just Goggle bearing pullers and it should come up.
BACKON2 is offline
post #10 of 11 (permalink) Old 05-22-2010, 10:35 AM Thread Starter
Xtracho's Avatar
Thanks...I'll check it out.....don't think I have a Harbor nearby here, but wondering if another store or shop may have one? Auto shop maybe? One that would not charge me an arm and a leg to pull it out?
Mark
Xtracho is offline
82 Gl wheel bearing removal t18skyguy Goldwing Technical Forum 5 08-20-2010 01:22 PM
Front wheel removal on 85 GL1200 aspy. HondaOW Goldwing Technical Forum 3 07-21-2010 10:38 PM
GL1200 Front Wheel Bearing Removal Frank vH Goldwing Technical Forum 9 05-18-2010 08:51 PM
84 GL1200 Front wheel removal pjfsail Goldwing Technical Forum 13 07-08-2008 06:20 PM
1984 GL1200 front wheel removal! BHall235 Goldwing Technical Forum 2 10-07-2004 05:37 PM
