Air Shock Air Pressure GL1200? - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 05-23-2010, 09:49 AM Thread Starter
I have a 1987 Interstate and have a set Progressive 416 shocks and have been trying to find the right air pressure combination for a less harsh ride with two up. I also have a set of Progressive springs and new seals in the front. Are the stock shocks a softer ride and should I rebuild them ?
Thanks
Ray D
Ray D is offline
post #2 of 3 (permalink) Old 05-23-2010, 10:47 AM
The Irish Crew
FitzAl's Avatar
Model: GL1100 Interstate
Some people find the Rear Progressives too hard. Lowering the air pressure will help a bit overall but it isn't a perfect solution.
Alan Fitzpatrick.
FitzAl is offline
post #3 of 3 (permalink) Old 05-24-2010, 10:14 AM
Jason's Avatar
Reducing the setting on the 416 might be better than reducing the air in the other shock. What have you got it set to now?
Jason
Jason is offline
Shock air pressure GL1500 Tank4300 Goldwing Technical Forum 7 04-01-2011 10:56 AM
GL1500 shock air pressure and air pressure for tires? Scott Wheeler Goldwing Technical Forum 13 11-01-2010 07:24 AM
1200i air shock pressure? orysglory3 Goldwing Technical Forum 2 03-19-2009 12:07 PM
air shock can't bleed off pressure cldryder Goldwing Technical Forum 7 06-13-2007 04:44 PM
Air shock pressure on 86 Interstate W3JNP Goldwing Technical Forum 1 07-16-2006 05:08 PM
