GL1500 flat spot off idle - Page 2 - Steve Saunders Goldwing Forums
post #11 of 11 (permalink) Old 05-30-2010, 10:20 AM
grambo's Avatar
yeah you gotta use fuel cleaner at least once and a while and at the first sign of trouble...also gotta blow em out and spray the sliders sooner or later...and use the cable graphite lube on the cables...wd40 is ok and really thin but any oil product will accumulate dirt etc again over the long run....oh! also when spraying down the throats it good to choke em off with your hands and let it suck hard thru your fingers...each side...of course!...and repeat.
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
89 gl1500 off idle flat spot 55b33 Goldwing Technical Forum 19 10-17-2009 06:56 PM
FLAT SPOT ohiojack Goldwing Technical Forum 6 06-12-2009 11:02 PM
Flat spot on 85 LTD Shorn Goldwing Technical Forum 2 07-06-2008 09:03 PM
Flat Spot Hockybro Goldwing Technical Forum 3 06-14-2008 11:49 PM
GL1500 FLAT SPOT scotwing Goldwing Technical Forum 11 02-02-2006 06:07 PM
