wing starts only sometimes - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 05-29-2010, 06:51 PM Thread Starter
I have my 1985 LTD in my garage on the center stand and it will start and run fine. I will shut it off and it won't start and the Fuel system light comes on. I will continue to attemt to start it and after five or six or seven...... trys it will start. All this time it has not moved. Could it be the fuel pump? I have replaced the dogbone fuse last year.
Thanks.
skygopher is offline
post #2 of 7 (permalink) Old 05-29-2010, 07:28 PM
sctrucker's Avatar
now that is sounding like a filter problem not getting enough fuel in, there is a filter INSIDE the feed line from the tank to the pump much like a a/c system, i had the same problem and the screen in the tank was full of gunk and i cleaned it and everything went fine from there but i think i would look at the fuel system, take the top off the tank and look at the screen, chech the petcock valve and the filter inside the line and then the fuel filter inline between the pump and the injection system
some of my past rides:
197? hd z90 sold
197? honda 500-4 traded this to get another engine for my first wing after the belt went within like 100 miles of buying it
1976 gl1000 dressed with all vetter sold
1985 gl1200 interstate sold
1986 gl1000 naked (traded this one to get the work done on my gl1200 sei
1983 magna vf750c (sold)
2010 vw trike (still trying to complete this one)
randy coffee
sctrucker is offline
post #3 of 7 (permalink) Old 05-29-2010, 07:31 PM
After you do the above, pour in a full can of Sea Foam for the next 2 or 3 tanks of fuel.
That will help to dissolve any solids that remain in the screens and lines.
post #4 of 7 (permalink) Old 05-29-2010, 08:53 PM Thread Starter
am curious if that would allow the bike to run good when it does start? I will clean all the filters though. Thanks
post #5 of 7 (permalink) Old 05-29-2010, 09:14 PM
sctrucker's Avatar
yes it will, you get a little fuel through and it will start fine but you wouldnt be able to ride it if it is the filters, and it may idle for long either
197? hd z90 sold
randy coffee
post #6 of 7 (permalink) Old 05-30-2010, 12:26 AM
roscoepc's Avatar
Check the CFI computer under the left side of the trunk for an error code per the shop manual next time you crank and run the bike. Also, are you aware that you have a 2nd 30amp dogbone fuse? It's located behind the starter selinoid and is an inline fuse...
Don
1985 Gl1200 Limited Edition
roscoepc is offline
post #7 of 7 (permalink) Old 05-30-2010, 10:23 AM Thread Starter
will continue to check out your suggestions. Thanks
cold starts on 88 Se oldsouthpaw Goldwing Technical Forum 1 05-07-2011 07:50 PM
It Starts Today BrianInPA General Motorcycle Discussion Forum 6 07-30-2010 10:26 PM
A beer before it starts... retiredintime Fun Forum 4 10-23-2008 04:18 AM
What starts with an F and ends with a K......?????? Papajoe Fun Forum 7 07-06-2008 06:26 PM
before it starts pinkpork Fun Forum 4 02-26-2007 06:08 AM
