PoorBoy Conversion - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 07-20-2010, 08:08 AM Thread Starter
jar
jar's Avatar
I put this conversion on little over a year ago and love it. This last weekend, I found that it was not charging the battery very well, I had the battery and alternator checked and both checked fine.
All I can figure is that the belt maybe stretching when it gets hot (been really hot here)
What do you guys think
GOD Bless,
jerry
1984 GL1200 Interstate
Romans 6:23
Member-CMA-Christian Motorcyclists Association
SwordBearers For Christ, Chapter 49
Independence, MO
jar is offline
post #2 of 12 (permalink) Old 07-20-2010, 09:04 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
your gonna have to check what the charging voltage is before,after and while the bike is hot
check all your battery connections real well,normally belt being loose does not affect anything,are you running a v-belt or the serp?
neoracer is offline
post #3 of 12 (permalink) Old 07-20-2010, 09:40 AM Thread Starter
jar
jar's Avatar
it is a belt with 3 grooves
Romans 6:23
Independence, MO
jar is offline
post #4 of 12 (permalink) Old 07-20-2010, 09:56 AM
morram's Avatar
maybe getting a 4 grove belt would increase the charge
do you monitor in real time?
cagers on cell phones scare me
I owe my life to a Stebel Nautilus
morram is offline
post #5 of 12 (permalink) Old 07-20-2010, 10:49 AM Thread Starter
jar
jar's Avatar
I have a gage on the dash which shows areas of red, yellow and green, when its cold it reads in the green and as it heats up, it starts going into the yellow/red areas, depends on the rpms at the time.
Romans 6:23
Independence, MO
jar is offline
post #6 of 12 (permalink) Old 07-20-2010, 11:36 AM
sandcastcb750's Avatar
Location: The shot heard round the world, Massachusetts, USA
Is the volt meter correct?
sandcastcb750 is offline
post #7 of 12 (permalink) Old 07-20-2010, 11:45 AM
azdesertdad's Avatar
Model: GL1100 Standard, GL1200-I, Kawasaki Vulcan 1600 Classic
Bad wiring. Resistance vs. Heat is a factor in all electrical wiring -
Check all your connections (pull the connectors and examine the plugs and connections)
It sounds to me like you've got a bad connection that is heating up, making a worse connection.
A wing isn't an old mans bike, it's a wise mans bike. Often that wisdom comes with age. Sometimes not at all.
Four wheels move the body. Two wheels move the soul
Do something. Something is always better than nothing.
IBA #69314
azdesertdad is offline
post #8 of 12 (permalink) Old 07-20-2010, 05:06 PM
sctrucker's Avatar
sounds to me like a lazy meter, you said they checked it and everything was good? then look to the wires going to your meter
some of my past rides:
197? hd z90 sold
197? honda 500-4 traded this to get another engine for my first wing after the belt went within like 100 miles of buying it
1976 gl1000 dressed with all vetter sold
1985 gl1200 interstate sold
1986 gl1000 naked (traded this one to get the work done on my gl1200 sei
1983 magna vf750c (sold)
2010 vw trike (still trying to complete this one)
randy coffee
sctrucker is offline
post #9 of 12 (permalink) Old 07-20-2010, 05:49 PM
tricky's Avatar
Year: 1985
Model: 85 Aspencade
1 a four rib belt will not fit on a 3 rib pulley.
Use a hand held volt meter on the battery terminals.
Check the belt adjustment.
tricky is offline
post #10 of 12 (permalink) Old 07-21-2010, 02:33 PM
86sei's Avatar
How much voltage variation are we talking here?
I have the conversion on my bike as well and depending on temperature it will vary between 13.7v and 14.3v. It never really effects my battery charge though because it never gets below 12.6 or full battery voltage.
I doubt that your belt is stretching much, there isn't much give in those serpentine belts. They also don't need to be nearly as tight at a V belt to get good grip.
86sei is offline
Poorboy conversion Downhomr Goldwing Technical Forum 24 08-26-2012 05:28 PM
Poorboy Conversion glnewbe Goldwing Technical Forum 27 02-15-2012 08:54 PM
POORBOY CONVERSION KIT mcbchild Goldwing Technical Forum 10 09-15-2011 10:04 AM
Poorboy conversion for 1100 Richardrwg Goldwing Technical Forum 3 03-25-2010 07:42 PM
Poorboy conversion on 1100 Bo Goldwing Technical Forum 3 05-20-2009 08:05 AM
