Progressive Suspension 416 series rebuild - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 09-01-2010, 11:30 AM Thread Starter
Carshandco's Avatar
Model: 1979 GL1000
I have a pair of Progressive #416 on my '79 GL1000 I need to replace the leaking seals..no problem finding them, but Progressive's instructions claim I'll need their tool #5500 to completely disassemble these shocks (GL1000's are different, have clevis mount on bottom, eye on top). Can anyone verify if this special (expensive & can't find) tool is really needed..can't I just pop out the seals & replace like a 1200 shock without complete disassembly? Thanx for any input, Carshandco
Carshandco is offline
post #2 of 5 (permalink) Old 09-01-2010, 12:05 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Give Progressive a call ( 714.523.8700 Barb can be quite helpful ) or visit em online for a live chat (http://www.progressivesuspension.com ).
You should be able to pop-out the main seal with a little "extra air pressure" after pulling the clip ... replacement is easily fitted -- the "special tool" is only needed if you wanna dig deeper into the shock and need to drop the spring pressure to get at some of the deeper seals and fittings.
(if you've done this before, the you already know what fun "popping-out" the seals can be !)
satan is offline
post #3 of 5 (permalink) Old 09-01-2010, 12:34 PM Thread Starter
Carshandco's Avatar
Model: 1979 GL1000
Thanx, Satan, I'll give it a try...didn't want to get in too deep without all the tools needed..
post #4 of 5 (permalink) Old 09-01-2010, 06:25 PM
Hobie1's Avatar
Good luck on your re-build, and get back on the road soon!! However, here's what I did with mine just a little while ago:
I recently had my 416's(5 years old 40k)completely re-built by Progressive for $120 + 20 shipping. They were losing air quickly.They turned them around in 24 hours and they went all the way through from replacing 1 damper, several seals and o-rings on both shocks. For the work they did and a new ride feel, was completely worth it.
Hobie
Mark
Wineberry 1983 Interstate
Hobie1 is offline
post #5 of 5 (permalink) Old 09-02-2010, 08:34 AM Thread Starter
Carshandco's Avatar
Model: 1979 GL1000
Thanx Hobie1 for that input...Carshandco
Progressive Shocks-- GL1500 Rear Air-- 416 Series IRAQI RAM For Sale/Wanted Forum 0 08-18-2011 05:15 PM
rebuild of progressive 416's williamchar Goldwing Technical Forum 4 04-06-2011 07:42 PM
416 progressive suspension jbhigg Goldwing Technical Forum 12 03-25-2009 01:21 PM
Progressive 416 shock rebuild Jonovich For Sale/Wanted Forum 4 11-23-2008 06:02 PM
Progressive Suspension Air Shock Rebuild Upgrade Kit B, Dampers (Honda GL1100 Gold Wing 1980-1983 cromagjeff Goldwing Technical Forum 2 03-31-2008 07:27 PM
