ABS plastic repair - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 09-13-2010, 08:14 PM Thread Starter
wingd's Avatar
I saw a thread somewhere on ABS plastic repair but can't find it. Anybody have a good product for crack repairin Hondaline saddlebags?
1981 GL1100S 2010 GL1800 Titanium
Wingd
wingd is offline
post #2 of 9 (permalink) Old 09-13-2010, 08:21 PM
Year: 1984
Model: GL1200
Hi, on my side I've been sucessfull with Permatex pastic epoxy available in car store. I think it's the same as Devcon plastic welder.
http://www.devcon.com/products/produ...&sc=Market
Andre Roy GL1200 glued!
Ydna is offline
post #3 of 9 (permalink) Old 09-13-2010, 08:52 PM
cbodnar's Avatar
For ABS plastic Honda fairings and bags it's hard to beat the black ABS solvent/cement like this one from Oatey. I have done a number of repairsusing ABS scrap pieces or back-up laminations (with fiberglass cloth) using this product and the results have always been as strong or stronger than the original. I've yet to have a failure on any repairs. Technique is important, though.
http://www.oatey.com/Plumber/Shared/...ck+Cement.html
2008 GL1800P
1983 GL1100 Interstate
1981 CB900 Custom
1978 CB750K
cbodnar is offline
post #4 of 9 (permalink) Old 09-13-2010, 09:20 PM
wpgfire's Avatar
Year: 97
+1 on the black ABS Cement.
I've even used a soldering gun to 'solder' a piece of ABS into a 2" hole on the backside of a saddlebag and then finished it with the cement. Have to look to find it.
Lawrence
'97 1500SE
wpgfire is offline
post #5 of 9 (permalink) Old 09-13-2010, 10:55 PM
Kendas's Avatar
Yep, ANY hardware/plumbing supply store should have ABS cement. The only complaint I have with it is the same as with PVC cement "bottles"... I HATE THAT BIG BALL THEY USE AS A BRUSH THAT IS ATTACHED TO THE TOP.
Ken
Ken S. - Old and one legged... But then again the 84 Interstate ain\'t what it used to be either.
Previous Bikes:
1983 Interstate
1975 GL1000 WJ III, Bates Bags, ARE Boot (115K)
2 1972 Yamaha Enduros
Kendas is offline
post #6 of 9 (permalink) Old 09-13-2010, 11:07 PM
desert wings's Avatar
ABS glue, fiberglass drywall 2" tape cut to fit it bends nicely to fit angles model brush to apply best in light layers
Happier then a slinky on an escalator.
desert wings is offline
post #7 of 9 (permalink) Old 09-14-2010, 02:36 AM
If it's just a crack you could try what I did. I didn't want to have to paint so I used Bondini 2 and then backed up the work on the inside with JB Weld.
The crack shows up white after waxing. Otherwise...
post #8 of 9 (permalink) Old 09-14-2010, 07:04 AM
tricky's Avatar
Year: 1985
Model: 85 Aspencade
http://faq.ninja250.org/wiki/Plastic...ith_ABS_cement
tricky is offline
post #9 of 9 (permalink) Old 09-14-2010, 08:00 AM
Reinyrooster's Avatar
Model: 2000 1500 SE
Plastex is the product I have used over the years and I love it.
Reinyrooster
Reinyrooster is offline
Black ABS Plastic Cement wcleafs2002 General Motorcycle Discussion Forum 17 07-03-2011 01:53 AM
Trunk/ ABS plastic repair GreyDino Goldwing Technical Forum 17 06-27-2011 08:57 AM
ABS plastic glue inspector 1 Goldwing Technical Forum 10 02-24-2010 06:26 AM
ABS Plastic repair Lower fairing tab mikeatrain Goldwing Technical Forum 21 07-03-2007 01:12 PM
Need ABS plastic jsmith24 General Motorcycle Discussion Forum 6 12-16-2004 07:16 AM
