1984 goldwing carb question - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 09-14-2010, 08:59 AM Thread Starter
Hey everybody
I recently purchased a 84 goldwing interstate and had problems with it only running on three cylinders. Thanks to everybody's help and advice I pulled the carbs and resolved that issue. When i pulled the carbs i noticed that the original carbs had been replaced with a set off a california bike. I pluged off the purge lines, hooked up the intake vacuum on #4 to the air cut off and anti backfire and ran a vacuum line from #4 carb to ignition vacuum. The bike runs good but seems to run even better when i run with choke on. I have no problems with the idle as i can adjust it up or down and still runs smoothly. I feel like the air cut off might need to be replaced as gas milage seems to be low although I don't have a specific number yet. It also tends to spit sometimes on deceleration. I have not synced the carbs yet, i just turned the adjustment out 2 turns.
the #4 plug looks great and the other three seem to be a bit rich. In 4th and 5th gear it runs smother about 3500rpm i didn't know if this was due to vacuum advance kicking in.
When i purchaqsed the bike i was fishing at lake erie and had no intention of buying a motorcycle but came home with one and have been entertained by it ever since. I am sure glad that i found such a wonder site with such great advice because if I hadn't got it running I very well could have been in a divorce chat room now.
thanks
steve
cdsasap is offline
post #2 of 2 (permalink) Old 09-14-2010, 09:17 AM
SuperSkypilot's Avatar
Try synchronizing the carbs first. You can do a search and find a homemade sync tool. Synchronizing the carbs will have less of an affect on higher RPMs. Rechecking float level will would be my next step. If your running rich they probably set a hair high.
Steve
SuperSkypilot is offline
Carb question, GL1500. Im afraid the question is generic muaymendez1 Goldwing Technical Forum 11 07-29-2012 10:18 AM
1984 carb rack GreyDino For Sale/Wanted Forum 3 04-15-2012 05:18 PM
1984 carb cough? Bvanemon Goldwing Technical Forum 9 10-14-2010 07:39 PM
1984 goldwing carb question cdsasap Goldwing Technical Forum 3 09-24-2010 06:52 AM
1984 GL1200 Carb p[roblem.. redwing52 Goldwing Technical Forum 5 10-30-2006 05:40 AM
