thermostat gasket 81 1100 - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 09-20-2010, 11:12 PM Thread Starter
#9 Man's Avatar
hi- shes running again. No gas in the [email protected]!!!!!!!!! But... i have a little leak from the thermostat housing. Is this gasket replaceable without yanking the radiatior? I had the radiator off and flushed it good but would like to replace thermo housing gasket without yanking the rad if possible. Now on to the front end and prep for paint!!!!
jeff
81 Rebuild
"If you think you can or you think you can\'t, you\'re right!"
#9 Man is offline
post #2 of 3 (permalink) Old 09-21-2010, 12:02 AM
peterbilt's Avatar
should just be two bolts holding on the t-stat housing
i am the current president of the non punctuators and bad spelling motorcycle group
peterbilt is offline
post #3 of 3 (permalink) Old 09-21-2010, 02:24 AM
notodd's Avatar
Send a message via MSN to notodd
you have to remove it. just went though that lol, you wont be able to get to the bolts if you dont plus its not hard and is quick.
82 gl 1100 Ok not naked anymore. Have pics, Now working on paint.
My name is Wayne
notodd is offline
Thermostat Gasket, 85 LTD jobe05 Goldwing Technical Forum 12 07-01-2012 07:37 AM
81 gl 1100 Thermostat ???? ssnova72 Goldwing Technical Forum 2 09-29-2011 08:11 PM
W T B-Thermostat 1982 GL 1100 SA Wingrider For Sale/Wanted Forum 1 09-14-2011 07:28 AM
87 1200 Thermostat gasket ErnieB Goldwing Technical Forum 5 02-08-2011 11:52 PM
Thermostat gasket needed for 77 GL1000?? bigcowhead Goldwing Technical Forum 4 05-10-2010 09:18 PM
