1800 cb error message on readout - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 09-30-2010, 08:31 PM Thread Starter
I have 04 1800, when i switch my music, (wheather it be radio or aux) from my headset to my outside speakers, I will get a message on my readout saying, CB ERROR, the message will be flashing, and my cb will not work. my cb works fine when i have my music coming through my headset. anybody have any ideas what my problem might be
chili is offline
post #2 of 6 (permalink) Old 10-01-2010, 09:24 AM
Other side of the pond
englishted's Avatar
Have you removed the saddle recently? You could have disturbed the large CB connector under there. Either way it is the first place to check when you get CB errors.
Ted Kelly.
englishted is offline
post #3 of 6 (permalink) Old 10-01-2010, 09:57 AM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
Yes, there is a good chance that englished is right. It doesn't take much for one of the many connectors to loosen up, also check the headset connector for the back seat, and the rear speaker connectors.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
post #4 of 6 (permalink) Old 10-01-2010, 11:40 AM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
Before digging under the saddle, disconnect the battery for a few minutes and reconnect, that works in many cases. Also check the antenna ground strap, they are known to break. If it's not broken, check the grounds for tightness and corrosion.
GWNorman is offline
post #5 of 6 (permalink) Old 10-03-2010, 07:11 PM Thread Starter
where is the antenna ground strap located??
chili is offline
post #6 of 6 (permalink) Old 10-04-2010, 06:52 AM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
In the trunk, it is the metal strap going from the cb antenna to a bolt in the bottom of your trunk.
On another note, I also found that if your cord going to your headset has a wet connection, it can also cause a CB error. Had that happen this weekend to me. Cleaned the connections and error was gone.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
GL 1800 CB goes to Error while riding h1500cc Goldwing Technical Forum 4 10-17-2011 11:21 AM
CB Error Message, GL1800 sermat Goldwing Technical Forum 6 12-18-2010 07:45 AM
Blinking CB Error message on dash Comanche Goldwing Technical Forum 7 06-26-2010 05:23 PM
GL 1800 CB error Stevie Goldwing Technical Forum 7 03-08-2010 08:27 AM
Error Message 2wings Miscellaneous Forum 47 04-02-2008 12:57 PM
