Headlight bulbs replacement on a 1500 - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 10-01-2010, 01:39 AM Thread Starter
Psalmist's Avatar
Send a message via Yahoo to Psalmist
After a long trip to Michigan I noticed one of my high beams was out. So I went to Honda and they wanted $20 for one bulb. The parts guy was nice enough to tell me that any H4 bulb would work. So I went to Auto Zone and bought a set for $20. But the wing tabs were the wrong size. So I took them back and finished my trip with one high beam. I put a pair of leftover used bulbs in and the tabs were also incorrect sizes. With some snips, they fit fine. Ebay sells the pr for $10 new shipped. You probably can go with the Sylvania for $10 each and just snip the two tabs at the top. The spring will probably keep them in fine.
Dino Hutchings
Fort Smith, AR
1999 pearl silver SE
Still trying to be pleasing before Jesus
Come to Arkansas and ride year round!
Psalmist is offline
post #2 of 11 (permalink) Old 10-01-2010, 01:49 AM
Been a long time, but I don't recall having to modify anything when I bought a set of Sylvania Superstar bulbs for my '94 1500.
I did buy the ones marked "for motorcycle use" though.
post #3 of 11 (permalink) Old 10-01-2010, 05:05 AM
Monkey with a Football
Rudy's Avatar
I believe Honda hosed up the 97-2000 where you needed an adapter ring to use H4 but the years before fit fine.
Cyclemax carries the adapter rings.
They are reusable.
Rudy
wasn't too much fun”
Rudy is offline
post #4 of 11 (permalink) Old 10-01-2010, 06:39 AM
Best looking member
Goldwinger's Avatar
Make: Honda, is there any other?
Model: 1997 SE. Pearl Green
Rudy wrote:
I believe Honda hosed up the 97-2000 where you needed an adaptor ring to use H4 but the years before fit fine.
They are reusable.
So close Rudy, 98 to 2000 used proprietary bulbs which need the adaptor rings to use standard H4.
Pearl Green(The Intelligent colour)
No question A.T.G.A.T.T. (Even when it's stinking hot!!)
And if it's too stinking hot to gear up, it's too stinking hot to ride.
If your not man enough to take the lead, stop complaining from behind.
I SURVIVED NASSIR 9.... barely.
To all of the troops and Vets. Thank you. I will never forget.
A proud Wild Rhino(Ontario) since 18 Jul 2013 (That mating sound thing really works!!)
Goldwinger is offline
post #5 of 11 (permalink) Old 10-01-2010, 06:59 AM
Rudy's Avatar
They are reusable.
Gotta leave some crumbs for the other guys.
Rudy
Rudy is offline
post #6 of 11 (permalink) Old 10-02-2010, 12:00 AM Thread Starter
Psalmist's Avatar
ok. no wonder I thought my old bulbs should fit. They came out of earlier 1500 wings. This 99 SE must be one of those that got 'hosed'.
Dino Hutchings
Fort Smith, AR
Psalmist is offline
post #7 of 11 (permalink) Old 10-02-2010, 06:18 AM
kcid's Avatar
Model: Goldwing SE
I bought a set of the adapters on EBAY, only to find out that the H-4 fit right in. I have never used the adapters, and if anyone is interested, let me know
USN RET
CT Patriot Guard
1997 GL1500 SE Pearl Green
If it ain't fun, why do it?
“Lest I keep my complacent way I must remember somewhere out there a person died for me today.
As long as there must be war, I ask and I must answer Was I Worth Dying For?”
[Eleanor Roosevelt]
kcid is offline
post #8 of 11 (permalink) Old 10-02-2010, 11:24 AM
Best looking member
Goldwinger's Avatar
Rudy wrote:
They are reusable.
You are a generous man Mr. Rudy:action :
post #9 of 11 (permalink) Old 10-02-2010, 10:24 PM
keithg64's Avatar
Model: GL1500SE
So will I have to have the adapters for my 2000 or can Isize the tabs to fit.
It\'s not what you buy, it\'s what you build.
Victory Riders CMA Road Captain:
Illinios Chapter Wild Rinos Member
keithg64 is offline
post #10 of 11 (permalink) Old 10-03-2010, 09:01 AM
Best looking member
Goldwinger's Avatar
You will probably want to get the adapters. If you size the bulb to fit, that will work until you are on the road when a bulb needs to be replaced. At least with the adapters, a standard H4 will fit with no mod's to the bulb.
Headlight Bulbs 1500 FeButter Goldwing Technical Forum 19 08-30-2012 10:38 PM
List of LED replacement bulbs for GL 1500 Keith Davidson Goldwing Technical Forum 2 01-13-2012 04:46 AM
GL 1500 Headlight replacement Buck Goldwing Technical Forum 11 07-25-2009 11:31 AM
Headlight replacement for 89 1500 w-82 Goldwing Technical Forum 3 09-10-2007 11:14 AM
88 1500 headlight bulbs tlc Goldwing Technical Forum 1 04-22-2006 02:51 AM
