Dyna beads - Page 2 - Steve Saunders Goldwing Forums
post #11 of 19 (permalink) Old 10-06-2010, 05:58 AM
Hickey's Avatar
Model: GL1500 SE
CENTRAMATICS ?? Never heard of it.
Hickey
70 Harley, 74 & 77 Suzuki, 86A Goldwing, 99SE Goldwing
ALR POST 820
PGR MEMBER
Hickey is offline
post #12 of 19 (permalink) Old 10-06-2010, 06:05 AM
www.wingstuff.com
I have them on both mine and my wifes.
We do a lot of rides.
cdayejr is offline
post #13 of 19 (permalink) Old 10-06-2010, 07:06 AM
06wing's Avatar
"The only problem with beds are they can get stuck in the valve stem,"
..... This could be a possibility.
"they make a mess when changing"
.....I change my own tires and I never had a mess with the beads. They always stay in the tire when I take it off the rim.
"and most of all when you travel you have to put air which puts moisture causing then to clump together and not work."
..... I have never experienced this problem. I have been using beads in my car, truck and both motorcycles (tubed and tubeless) tires for several years now and I have not experienced any problems at all. I ride over 50K per year. BTW, they do work.
Dave
Webmaster - GWTA PA-J
PGR member
2006 HONDA Goldwing - Comfort/Audio/NAV
1996 Suzuki VS800 Intruder
Retired Electrical / Electronics Engineer
Amateur Radio Operator since 1963 - KN3ZAN (Advanced class)
USAF: 1969-1973 - Presidential Aeronautical SSB Radio Station
06wing is offline
post #14 of 19 (permalink) Old 10-06-2010, 08:00 AM
Hawker22's Avatar
There may be some issues with moisture inside the tire causing the beads to cluster. I added them to my tires, which had been mounted about 2 mos earlier(delay was waiting for the beads to arrive). I watched the guy mount my back tire(CT) and he was very liberal with the bead lube and may have gotten some inside the tire. THAT would spell trouble for the beads. I do have a small shimmy now, and that may be the problem. Another possibility is the fact that it is a wide car tire and the beads cannot handle the lateral balance.
Hawker22(Ken)
Per Ardua Ad Astra
1997 GL1500SE--White Cloud
2001 GL1800----Blue Yonder
Hawker22 is offline
post #15 of 19 (permalink) Old 10-06-2010, 09:39 AM
Halfling's Avatar
Model: 2003 GL1800A
Send a message via Skype™ to Halfling
My new front tire (Elite 3) and supply of Dyna Beads should arrive tomorrow! I'll let you know how it goes.
2003 GL1800A Candy Durango Red
US Navy (77-93) EWC(SW)
Darksider # 817 (195-55-R16 Michelin Primacy Alpin PA3 ZP @ 29.5 lbs)
Co-owner
"Seek out that particular mental attribute which makes you feel most deeply and vitally alive, along with which comes the inner voice which says, 'This is the real me,' and when you have found that attitude, follow it." - James Truslow Adams
Halfling is offline
post #16 of 19 (permalink) Old 10-06-2010, 09:55 AM
Robin's Avatar
They can be used on trucks etc,
You may need to have another oz of beads in or if you have a lateral balance problem I would suspect tyre is faulty.
Long and distant past. CB175, CB400/4, GL1000, 2 GL1100\'s & GL1200 Aspencade.
Then kids came along
Burgman 200 (2007-2009)
BMW RT1150RT (that was awful to ride but pretty) (in 2008).
Burgman 650 Exec from jan 2009 till july 2010.
Got an old but good 1500 SE 1992 in Aug 2010.
Currently wingless.
Robin is offline
post #17 of 19 (permalink) Old 10-06-2010, 07:50 PM Thread Starter
oldsouthpaw's Avatar
ordered two bridgestone tires and 4 oz of dyna beads getting ready to head to Wisconsin Sunday for about a 2,500 mile ride will let you know how they do
quit running from lifes storms, just learn to ride in the rain!
oldsouthpaw is offline
post #18 of 19 (permalink) Old 10-06-2010, 07:58 PM
Hello, I put them in my front tire (dunlop 177) 4000 miles ago and have had no problems . the bike runs smooth at 85mph so I figure they work great.
furnacedoc is offline
post #19 of 19 (permalink) Old 10-06-2010, 08:29 PM
Webtrack's Avatar
Send a message via Yahoo to Webtrack
Centimatics are great... but they only offer them for the 1800's. No fit for our older bikes. They do offer them for "most" the harleys.
Webby
Webtrack is offline
Use "Counteract Balancing Beads" Instead of Dyna Beads? BillW Goldwing Technical Forum 9 05-12-2012 02:34 PM
Dyna Beads ceasefire49 Goldwing Technical Forum 4 08-26-2011 01:55 PM
Dyna Beads Nomad55 General Motorcycle Discussion Forum 11 06-26-2011 10:34 PM
Dyna Beads johnv50 Goldwing Technical Forum 8 05-11-2011 08:50 PM
Dyna Beads Scooter777 Goldwing Technical Forum 19 02-28-2010 02:35 PM
