carb sync and air mix screws - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 10-07-2010, 08:45 AM Thread Starter
#9 Man's Avatar
does anyone know if there is a good tutorial on how to sync the carbs other than in the Clymer manual i have? Also i know the 1.5 turns is just a starting point on the idle mix screws but how do you adjust once installed and how much difference do they make on /with the carb sync. I just cant seem to get the sync right . thanks
jeff
81 rebuild
"If you think you can or you think you can\'t, you\'re right!"
#9 Man is offline
post #2 of 14 (permalink) Old 10-07-2010, 09:27 AM
RB
RB's Avatar
Send a message via AIM to RB
Synch first..then use tach to drop idle on each carb with the air mix..which actually is fuel mix...then check sycn again..two completely different issues..synch matches air flow of each carb so it's even at idle..mixture screw adjust fuel flow at idle by watching idle and when it drops a bit you set screw back a bit.
There is a how to in the index..and ref. section.
http://goldwingdocs.com/forum/viewto...?f=11&t=81
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #3 of 14 (permalink) Old 10-07-2010, 09:35 AM
morram's Avatar
Getting the sync "right" is just a matter of practice and patience.
Depending on how far each carb is off from the primary and how stable your tool is makes a difference as well.
I use a set of gauges and they'll jump a lot until I get the three carbs pretty close. Once I'm closing in I start seeing all the needles settle down and pointing to common numbers.
Like RB said, set your idle last and use your tach.
Main thing is not to rush each step, let the engine settle after each adjustment.
cagers on cell phones scare me
I owe my life to a Stebel Nautilus
morram is offline
post #4 of 14 (permalink) Old 10-07-2010, 11:17 AM
Piled Higher and Deeper
sandiegobrass's Avatar
morram wrote:
Getting the sync "right" is just a matter of practice and patience. ..
Yup.. and you can work yourself into a box that is hard to get out of easily if not careful.. (getting a throttle plate too far closed)
not to explain.. but to avoidthese problems, I turn up the idle (with the idle screw) to at least 2000 rpm.. sync as best I can without worrying about rpm... then turn it back down to idle (about 1000) and do a fine tune with the sync.. avoids getting any throttle plate closed
AKA "Jim"
Have a Gold Wing? Look at the
! even though they closed this one it has the best graphics and is valid.
2000 GL1500SE
1983 GL1100I
But formerly San Diego, Terra Haute, Aiken, Oak Ridge, Tonopah NV, Pasadena CA, Aiken SC, Richland WA, and now back to Tonopah NV..)
sandiegobrass is offline
post #5 of 14 (permalink) Old 10-07-2010, 03:08 PM
Make certain you have no air sucking from anywhere, especially the O-rings at the manifolds.
A small vac leak will make it look good one moment, then bad on another moment, getting you to start all over again.
Patience is good too.
CaptainMidnight85 is offline
post #6 of 14 (permalink) Old 10-07-2010, 10:16 PM Thread Starter
#9 Man's Avatar
ok- all good advice. I did finally learn to establish a basline reading off of 3 then sync 1 to it. Then sync 2 to 4 using the middle screw and then left side to right side using the adjuster behind 4. Problem is - when i get to 4 and try to adjust the idle runs away with itself. Also- idle mix screws- go with 1.5 turns out and do not touch them? I am still having low readings on 1 and 3 header pipes. Ugh! Thanks
jeff
81 rebuild
#9 Man is offline
post #7 of 14 (permalink) Old 10-07-2010, 10:24 PM
Passed On, R.I.P.
Bagmaster's Avatar
the 1.5 turn outs are just your base starting point for the idle mixture screws..You still need to do the idle drop procedure after getting the carb sync done.
And if you haven't read the idle drop procedure in the manual then either you've skipped over that section or you don't have a good manual.
When ever I sync carbs and the idle starts to creep up on me then I adjust it back down, then continue till done. I may have to adjust it half a dozen times before I'm done.
Michael
USS Saratoga, ships company
Bagmaster, our former forum Toolmaster and friend, is no longer with us. He passed away in February 2012.
The roads and byways, no matter how beautiful and exhilarating, are a lonelier place now. RIP Bagmaster (Baggy).
Bagmaster is offline
post #8 of 14 (permalink) Old 10-07-2010, 10:26 PM
jeff
81 rebuild
Use Jim's 2000rpm trick.
Are the carbs from an '81 as well? If not, make sure you start with the mixture screw adjustment for the carbs you have. You will have to do an idle drop procedure to get those screws set to optimum.
post #9 of 14 (permalink) Old 10-08-2010, 08:11 AM Thread Starter
#9 Man's Avatar
yes, they are 81 carbs and i started with the 1.5 turns out. I will probably attempt another sync this weekend. I will look for the idle drop procedure in my Clymer manual.
thanks
#9 Man is offline
post #10 of 14 (permalink) Old 10-08-2010, 06:02 PM Thread Starter
#9 Man's Avatar
i'm really dismayed. # 1 and #3 cylinders continue to plauge this bike. Enough that i would just check and see what diff it made if i just removed the sync adjustment screws while it was running. Well, basically NONE. These are the cylinders that continue to run on the cold side # 3 under 200 and # 1 around 100 F. Did the same thing when i adjusted the other side and it killed the bike.
What besides carbs could be causing this. Fat spark on both cylinders, Cleaned pilot jets recently. Would readjusting the valves again help? I just dont know where to turn.
Jeff
81 rebuild
#9 Man is offline
GL1100 Interstate Carb Air Screws Wanted vampire963 For Sale/Wanted Forum 2 12-06-2010 02:45 PM
Gas / Air mix adjustments GL1100.. Where to start? goldie4ever Goldwing Technical Forum 13 05-28-2010 08:40 PM
twisted off idle mix screws 80 - 81 carbs 2Dahorizon Goldwing Technical Forum 11 03-27-2010 12:50 PM
locktite on idle mix screws? brianinmaine Goldwing Technical Forum 9 07-29-2009 04:29 PM
carb mix glennuk Goldwing Technical Forum 4 05-19-2005 03:20 AM
