2005 gla 1800 front fork servicing and bearing replacement - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 10-16-2010, 08:18 PM Thread Starter
hello pal, been doing alot of riding, well another question, this what i have now, running dyna beads, nitrogen, kerk fron billet fork brace tires have mininual cupping have 12k miles on them, wanting to upgrade front end and put in some progressive springs, any ideas, and how easy is it to service the shocks and while apart i will put in a new front bearing, any help would be needed thanks Huck
A BAD DAY RIDING BEATS A DAY IN THE RECLINER
old141fe is offline
post #2 of 2 (permalink) Old 10-17-2010, 07:05 AM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
The shock at the rear is easy to get at under the right saddlebag. All you can do with that is refill with oil. The front wheel bearing is easy to do, and pulling the wheel to do the job is about the same as for the Gl1500.
GWNorman is offline
2005 gla 1800 dash part info needed old141fe Goldwing Technical Forum 6 11-22-2010 06:16 PM
wanted carbon fiber parts 2005 1800 gla old141fe For Sale/Wanted Forum 0 11-18-2010 06:46 PM
which satelite radio for a 2005 gla 1800 old141fe General Motorcycle Discussion Forum 1 04-09-2010 10:42 PM
front fork removal on a 2005 gla 1800 wing old141fe Goldwing Technical Forum 6 02-27-2010 08:05 AM
FRONT BEARING REPLACEMENT Brian K Goldwing Technical Forum 11 05-25-2009 03:49 PM
