Dyna beads - Steve Saunders Goldwing Forums
post #1 of 19 (permalink) Old 11-02-2010, 08:28 PM Thread Starter
I would like to know how the dynna bids work best with air or nitrogen
trikevini is offline
post #2 of 19 (permalink) Old 11-02-2010, 08:30 PM
Halfling's Avatar
Model: 2003 GL1800A
Send a message via Skype™ to Halfling
Hi trikevini! - Welcome aboard
the Steve Saunders Goldwing Forum!It's a pleasure to have you with us! Please feel free to browse around and make yourself at home!
I'm sure someone will be along shortly to answer your question.I use mine with air, never tried it with nitrogen.
Again, WELCOME ABOARD!!!
John (Halfling)
2003 GL1800A Candy Durango Red
US Navy (77-93) EWC(SW)
Darksider # 817 (195-55-R16 Michelin Primacy Alpin PA3 ZP @ 29.5 lbs)
Co-owner
"Seek out that particular mental attribute which makes you feel most deeply and vitally alive, along with which comes the inner voice which says, 'This is the real me,' and when you have found that attitude, follow it." - James Truslow Adams
Halfling is offline
post #3 of 19 (permalink) Old 11-03-2010, 04:57 AM
The Irish Crew
FitzAl's Avatar
Model: GL1100 Interstate
Welcome aboard. I've been reading up on Dyna beads and it seems they work just as well in nitrogen or air.
Alan Fitzpatrick.
FitzAl is offline
post #4 of 19 (permalink) Old 11-03-2010, 07:45 AM
Robin's Avatar
Certainly work fine with air in my 1500
Long and distant past. CB175, CB400/4, GL1000, 2 GL1100\'s & GL1200 Aspencade.
Then kids came along
Burgman 200 (2007-2009)
BMW RT1150RT (that was awful to ride but pretty) (in 2008).
Burgman 650 Exec from jan 2009 till july 2010.
Got an old but good 1500 SE 1992 in Aug 2010.
Currently wingless.
Robin is offline
post #5 of 19 (permalink) Old 11-03-2010, 08:53 AM
Bruce County Boy/Snowbird
Hawggy's Avatar
Model: 07 GL1800
Same here for me on the rear tire.
We own a 2007 Goldwing with 65,000 KM ( 39,000 Mi. ) on it.
The best part about owning a wing is you know what your next bike is going to be. ( We know, we just bought our 3rd Goldwing )
Hawggy is offline
post #6 of 19 (permalink) Old 11-04-2010, 08:25 AM
Nobody
kennyd's Avatar
I have DynaBeads both front and rear, with regular air (That's 78% nitrogen anyway isn't it)
Works great. I am not paying to fill my tires.
2005 GL1800
kennyd is offline
post #7 of 19 (permalink) Old 11-04-2010, 08:46 AM
works fine in two of my tires, but only 78% nitrogen mixed with that lowly stuff called oxygen
post #8 of 19 (permalink) Old 11-04-2010, 02:43 PM
The think to watch with dyna beads is the goo used to mount tires, and air lines with excessive amounts of water in them.
broncbob is offline
post #9 of 19 (permalink) Old 11-04-2010, 04:04 PM
choppas's Avatar
The beads work, as broncobob says a possible issue is with tire goo and sealer. They slow the beads down. I think they still work anyways, they work fine for me with slime in the tires.
Tom, GL1800
choppas is offline
post #10 of 19 (permalink) Old 11-04-2010, 05:08 PM
Never heard of Dyna beads, but I am assuming they work on the same principle as the Counter-Act I sell for balancing semi tires.
There will be exactly 0.00% difference in their performance with air or nitrogen. Moisture should also not make a difference, as it is a bead and not a powder. The old Equal balancing powder had problems clumping in the cold northern climate if it got wet.
I wouldn't suggest running it with slime or any kind of sealant though... not that I suggest those anyways.
huzbum is offline
Use "Counteract Balancing Beads" Instead of Dyna Beads? BillW Goldwing Technical Forum 9 05-12-2012 02:34 PM
Dyna Beads Nomad55 General Motorcycle Discussion Forum 11 06-26-2011 10:34 PM
Dyna Beads johnv50 Goldwing Technical Forum 8 05-11-2011 08:50 PM
Dyna beads oldsouthpaw Goldwing Technical Forum 18 10-06-2010 08:29 PM
Dyna Beads Scooter777 Goldwing Technical Forum 19 02-28-2010 02:35 PM
