Headlite change - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 11-04-2010, 04:01 PM Thread Starter
PORKCHOP's Avatar
Would someone please tell me how to change the headlite on an 2003 Gl 1800?
Or refer me to a site????
THANK YOU
DANIEL EARLEY/ 2003 Black 1800
Master Mason
32 Scottish Rite
Shrine
Patriot Guard
100% Disabled Vietnam Vet/ 1970 Armored Cavelry
VFW
DARKSIDER 852
PORKCHOP is offline
post #2 of 5 (permalink) Old 11-04-2010, 05:46 PM
BenMilner's Avatar
You mean the whole headlight or just one of the bulbs?
BenMilner is offline
post #3 of 5 (permalink) Old 11-04-2010, 05:55 PM
JWayne's Avatar
Model: GL1800 abs
If its the whole headlight, it is in 2 parts and is attached to the lower side panels/cowls. The panels have to be removed to unscrew the headlights.
JWayne is offline
post #4 of 5 (permalink) Old 11-04-2010, 06:20 PM
GoWing's Avatar
The headlight left and right units come off with the front fairing panels. You won't need to remove the shelter, which is a nice surprise.
Pull off the faining mouldings, the long ones that run down along side the fairing packets and controls, then remove the Allen head bolts under the trim. Then the windshield garnish and the windshield.
the flange bolts along the top of the fairings/headlight assembly are next and while you pull the whole lot forward, disconect the 6 headlight connector plugs and the bank angle sensor.
Larry.
GoWing is offline
post #5 of 5 (permalink) Old 11-05-2010, 04:02 AM
Zeke66's Avatar
Don't forget to connect the bank angle sensor back in later or the bike won't start.....
Zeke66 is offline
Looking towards a change DriverRider Miscellaneous Forum 9 04-15-2012 08:53 PM
1800 headlite change Wingboomer Goldwing Technical Forum 4 09-09-2009 11:44 PM
headlite question beachbuddy0253 General Motorcycle Discussion Forum 7 10-25-2008 09:18 PM
The Book Says Don't Change the Oil(first change) til 4,000 miles instead of 600miles? gixxerbill Goldwing Technical Forum 3 06-25-2007 04:06 AM
headlite protector cyclepath General Motorcycle Discussion Forum 6 01-20-2007 05:29 PM
