85 Aspencade Problem - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 11-12-2010, 07:25 PM Thread Starter
Nightrider1's Avatar
Send a message via MSN to Nightrider1 Send a message via Yahoo to Nightrider1
please help. Someone may know about. I got a problem I need some help on. Does the 85 Aspencade have a hydraulic clutch? I am getting fuel and a good spark x 4, but no clutch. Will this keep the wing from cranking up? I am at my whits end. Im stumped. All the fuses are ok. Can anyone help out on this question? An 80 thru 83 i have no problem with this. Thank you, Sincerely, David
You meet the best people who ride a Goldwing
Nightrider1 is offline
post #2 of 5 (permalink) Old 11-12-2010, 08:14 PM
jackjohn's Avatar
Hi David, yes all 1200's have a hydraulic clutch but whether the clutch works or not will not prevent it from starting. Now if the bike is in gear and the clutch lever is not pulled (or due to a bad switch the system thinks it is not pulled) the engine will not start. Ignition on, transmission in neutral, kill switch in the on position the bike should start without regard to the clutch.
Jack
2012 GL1800A
2004 GL1800A Sold
1982 GL1100I Sold
1975 GL1000 Sold
1974 CB450 Sold
jackjohn is offline
post #3 of 5 (permalink) Old 11-12-2010, 08:29 PM Thread Starter
Thanks Jack. I believe i must have a bad switch. Sincerely, David
post #4 of 5 (permalink) Old 11-13-2010, 04:33 AM Thread Starter
Jack, where is the clutch switch located? Thank you. Sincerely, David
post #5 of 5 (permalink) Old 11-13-2010, 05:20 AM
Is the engine turning over or not? If the starter is not working that is 1 thing, if it will not start is another and the clutch working or not is another issue all together and until the engine runs you have no need for a clutch. If as in your first post it has spark it must be turning over so the clutch switch is not an issue.
First thing, have you had it running or is it new to you and you are trying to start it for the first time?
85 aspencade elctrical problem Decal Wizard Goldwing Technical Forum 9 09-10-2009 12:59 PM
'83 Aspencade radio problem Straydog Goldwing Technical Forum 3 06-18-2008 03:50 PM
84 aspencade starter problem got1 Goldwing Technical Forum 7 04-26-2008 10:41 PM
83 aspencade radio problem JBz Goldwing Technical Forum 12 07-20-2007 05:08 PM
84 aspencade speedo problem got1 Goldwing Technical Forum 4 05-24-2007 09:24 AM
