Taking off the GL1500 reverse handle? - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 01-18-2011, 05:26 AM Thread Starter
vtxcandyred's Avatar
I've looked through the book several times and all I can find is one chapter tells me to remove the body panel and to look in another chapter then I go to that chapter and it says to remove the handle and look in the previous chapter. I would just like the nuts and bolts. I have most everything apart EXCEPT that side panel which is still being held by the reverse handle. Thanks.
If I had know grankids were this much fun, I would have had them FIRST!!!!!!!!!!!
vtxcandyred is offline
post #2 of 4 (permalink) Old 01-18-2011, 05:41 AM
Bamaeagle's Avatar
Year: 2005
On the handle if you have a chrome cover on it you will need to take it off. You take it off by pulling up on it toward the front of the bike. After you pull it off or if yours does not have the chrome on it then you just pull on the rubber part toward the rear of the bike. Do not pull the rubber all the way off. Under the rubber you will see a hex socket bolt. I am not sure of the size but it is metric and big. Loosen the bolt and the handle should come right off. When replacing be sure to put the pin in the correct spot before tightening the bolt back.
ROLL TIDE ROLL !!!
Member- Warriors Watch Riders
You meet the nicest people on a Goldwing!!!!
Young Riders pick a destination and Go!
Older Riders pick a direction and Go!
Darkside Rear Tire: Federal FORMOZA FD2 175/60 R16 82H (GL1500)
Double Darkside-Bridgestone Battlax BT45 130/70/18 Front, Achilles Platinum 195/60/R16 Rear (GL1800)
Darksider # 1147
Bamaeagle is offline
post #3 of 4 (permalink) Old 01-18-2011, 05:43 AM Thread Starter
Thank you, Thank you, Thank you! I do have the chrome cover and wasn't sure if it had to come off or not.
post #4 of 4 (permalink) Old 01-18-2011, 06:00 AM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
On mine I slide the rubber cover towards the front of the bike, just enough to get to the Allen bolt.
GWNorman is offline
GL1500 Right handle bar sw. Remove and replace how to. buster8290 Goldwing Technical Forum 1 07-12-2012 10:33 PM
GL1500, need some risers or handle bar extensions jonhoggatt Goldwing Technical Forum 7 05-15-2012 10:34 AM
GL1500 REVERSE HANDLE happer Goldwing Technical Forum 3 05-14-2012 09:46 AM
Taking off the GL1500 rear wheel Tank4300 Goldwing Technical Forum 4 05-31-2011 06:48 AM
Handle bar end weights GL1500 waggawing Goldwing Technical Forum 7 03-06-2011 10:27 PM
