1982 1100 Accelertor pump leaking what is an easy fix? - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 01-31-2011, 04:46 PM Thread Starter
I have noticed that gas is dripping by the gas line than enters the carb from fuel pump(leaking at the carb)... when I decelerate at an idle. I can see it leaking on the opposite side of fuel line (I thought this would be an easy fix "just tighten hose clamp at the carb nipple" didn't help). It doesn't leak when I rev the throttle just when I back it off. So do I need to take the carbs off and then get an accelerator pump rebuild kit, o-ring or what? Will I have to re-sync carbs?
Thanks
ryster is offline
post #2 of 4 (permalink) Old 01-31-2011, 07:41 PM
You may want to go ahead and take it apart. If it was running properly before this happened, it may not need a Randakk rebuild, just certain rings that are letting it leak. Can't hurt to go ahead and change everything out though.
chris in va is offline
post #3 of 4 (permalink) Old 01-31-2011, 08:51 PM
Your post is slightly confusing, is it leaking at the accelerator pump or at the fuel inlet? If the pump is leaking you can get an accelerator pump kit separately, remove the carbs, turn them upside down and change it. If it is leaking at the fuel inlet there are 2 o-rings on the nipple where it goes into the carb body. The screw that holds the nipple in also holds the accelerator pump linkage so it's a bit tricky.
post #4 of 4 (permalink) Old 02-01-2011, 05:13 AM Thread Starter
Sorry about the confusing post...gas is dripping right where fuel line enters carb, so I thought the gas line hose clamp needed tightened and that didn't fix it. Someone told me its probably the acc. pump?
ryster is offline
GL1500 fuel pump replacement with - Napa P72190 pump is easy fix ttiger Reference and FAQ Forum 64 09-16-2017 07:15 PM
LTD, SEi. How to fix fuel pump and where to buy one for $20 newbiker Goldwing Technical Forum 27 04-15-2012 08:14 PM
1982 1100 leaking antifreeze Broncoman Goldwing Technical Forum 13 07-31-2011 04:10 PM
1982 goldwing aspencade w/ trailer for sale. parts or fix. tim_fellows For Sale/Wanted Forum 60 10-21-2008 02:11 PM
Carburator Bowl Screws easy fix Bill Turpin Goldwing Technical Forum 3 03-14-2008 12:31 AM
