1986 gl1200 clutch slave cylinder repair? - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 03-13-2011, 11:45 AM Thread Starter
snowman6454's Avatar
Send a message via AIM to snowman6454
Hi guys, I have read the honda manual to repair the cylinder, I looked at it and where it is and I kinda feel that there ismore to it than what is in the manual.
FYI: I don't have a lift to raise the bike up off the ground so is it as simple as stated in the manual? Does anyone have any tips that could make this an easy job? Anything to look out for that would cost many hours of time and frustration.
ANY informatin would great.
Thanks
Snowman
snowman6454 is offline
post #2 of 3 (permalink) Old 03-13-2011, 02:19 PM
Bigmick's Avatar
Snowman I had to rebuild mine and I didnt have a lift also. If you put it on the centerstand you can access it. I used a (and dont quote me on the size because its been awhile) 8mm ratcheting wrench to get at the bolts and make it easier. Its a little bit of a snug fit under there but it can be done. They didnt give us a whole lot of room behind the engine but its doable with some patience. The previous owner of my 1200 hadnt changed the clutch and brake fluids probably in at least 10 years ,so I had brown jellied brake fluidin the slave and master. The bad part was that because of what he didnt do caused corrosion in the cylinder of the slave due to the moisture forming on the metal under the brown jellied clutch fluid. So I had no choice as to rebuild it. To bleed the unit after I rebuilt it I used a Mityvac to get it bled and it took a bit to get it bled.
Old age is like fine wine,you just get better.
Honorary Rhino
Nassir 5
Nassir 7
Bigmick is offline
post #3 of 3 (permalink) Old 03-13-2011, 02:24 PM
CrystalPistol's Avatar
It's easy and most of the seals / rings are the same as those in a 1500s slave. I compared part nos. once.
...(Candy Spectra Red )
CrystalPistol is offline
GL1200 slave cylinder for clutch shortywing Goldwing Technical Forum 3 11-26-2010 07:36 PM
Clutch fluid leaking from GL1200 Slave Cylinder Ronbo Goldwing Technical Forum 5 08-05-2010 09:36 PM
Clutch Slave Cylinder AlsGoldWing Goldwing Technical Forum 3 05-18-2009 07:16 PM
Clutch slave cylinder limo$mitch Goldwing Technical Forum 22 04-10-2007 11:32 AM
Bleeding clutch slave cylinder aslakeview Goldwing Technical Forum 7 09-14-2006 01:28 AM
