Tire Balance Rear GL1500 - Steve Saunders Goldwing Forums
post #1 of 18 (permalink) Old 03-27-2011, 07:35 AM Thread Starter
keithg64's Avatar
Model: GL1500SE
I bought a new tire from J&P Cycle and have mounted it and am now balancing it. I am useing a static balancer that I have use several times. I started adding weight and thought I was using to much so I broke the bead down and rotated the tire 180 derees and tried again, and it nowhas about 100 grams of wieght on it, the manual says no more than 70 grams to the rear tire.
The mark on the tire was at the valve stem and that is where I added weight the first time, rotated the tire and the weight has followed the tire, it is now 180 from valve stem.
Could the tire weight be off that much or could there be something else going on.
These are E3 Dunlops
It\'s not what you buy, it\'s what you build.
Victory Riders CMA Road Captain:
Illinios Chapter Wild Rinos Member
keithg64 is offline
post #2 of 18 (permalink) Old 03-27-2011, 07:50 AM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
This is how I do it with my $37HF Wheel Balancing stand, Keith.
http://www.youtube.com/watch?v=bBzviKTPMrg
PS - I like to find the heavy spot on the bare rim 1st(after I've cleanedup the inside shoulder) and then mount the tire so the 'dot' is matched up with the heavyspot I marked on the rim. I rarely have to use any weights that way.
Dusty
- just another Rider
Dusty Boots is offline
post #3 of 18 (permalink) Old 03-27-2011, 08:22 AM
Luxo2r's Avatar
Model: GL1800 - 2002
Send a message via Yahoo to Luxo2r
Personally I use Dyna Beads - 2oz in the tire works great!
Al B
How many wrenches can one man own? Don\'t ask silly questions!
GWRRA Life Member #15513
Former MSF Instructor
Mason - Shriner - 2B1ASK1
American Legion SAL Post #166
Thanks to all those who served.
Luxo2r is offline
post #4 of 18 (permalink) Old 03-27-2011, 10:26 AM
Greener's Avatar
Make: Glodwing SE
Model: 1997 Pearl White
I am using Dyna Beads as well......I looked at Ken's balancing gizmo ....looks like it would work.Dont the Dyna Beads do a good job??
I just had new set of tires E3's and valve stems (yup got it done Ken) and would consider lead weights if anyon can give me good reason to not use Dyna Beads.
Regards,
Greener
Regards,
Greener
1997 GL1500 SE
Greener is offline
post #5 of 18 (permalink) Old 03-27-2011, 10:35 AM
Spondulas's Avatar
Remove the tire and all weights. Try "trial balancing" the bare rim to find the heavy spot and fitting the dot on the tire (light spot) to the known heavy spot on the wheel and then re-balance the whole assembly. If it still exceeds takes a lot of weight, tire is out of spec and needs to be replaced.
Spondulas is offline
post #6 of 18 (permalink) Old 03-27-2011, 10:42 AM
JimnWendy's Avatar
Model: 1991, made in the USA!
I would take it to a friendly tyre balancer with a balance machine. These machines are so accurate they even pick up on which side of the wheel needs the weight. Any tyre shop that sells bike tyres should be capable of doing a good job!
If it aint broke?....don\'t fix it?....keep riding it!
JimnWendy is offline
post #7 of 18 (permalink) Old 03-27-2011, 11:23 AM
Dyna Beads or antifreeze. Either works great.
post #8 of 18 (permalink) Old 03-27-2011, 11:44 AM
Scooter 7's Avatar
Location: Fromerly-Rhode Island. Currently, Kansas City KS USA
Year: 1998
Model: Goldwing SE
WOW...never heard of antifreeze!!??
Scott
1990 GL1500A
1982 GL 1100I "Phoenix"
1984 VF 1100 Magna (rocket ship)sold
Road Captain,CMA Chapter
God\'s Posse
Luke 19:10
Scooter 7 is offline
post #9 of 18 (permalink) Old 03-27-2011, 11:48 AM
cired99's Avatar
+1 dyna beads....
Today is the tomorrow you worried about yesterday!
Deric
cired99 is offline
post #10 of 18 (permalink) Old 03-27-2011, 12:38 PM
Hodgy's Avatar
Model: 97' SE, Two Tone Red --> 124,024 km as of November 2015
Put in Dyna beads front and back last year. Works for me.
Avatar Photo was taken in the Crowsnest Pass between Alberta and British Columbia on Highway 3.
Hodgy is offline
Rear Tire, GL1500 Chiefandmiskitty Goldwing Technical Forum 12 06-21-2012 07:39 AM
Tire balance and sealant Spear Chucker General Motorcycle Discussion Forum 8 10-29-2011 07:59 PM
GL1500 rear tire basstracker Goldwing Technical Forum 4 01-09-2011 11:50 AM
ceramic beads to balance the tire shakes on wings old141fe Goldwing Technical Forum 25 03-05-2010 12:36 AM
Tire Mounting & Balance question? bel25455 Goldwing Technical Forum 2 08-10-2006 10:26 AM
