GL1200 Water drip Question and Choke lever Question - Steve Saunders Goldwing Forums
post #1 of 24 (permalink) Old 04-01-2011, 06:43 PM Thread Starter
RoyP's Avatar
Ok fellas, on my 1200 I have started to get a water drip from what appears to be in between the front engine cover (large) and the block, right on the very bottom. My buddy Al`s has a small leak in the same spot as does my brothers 1200 also. So thats 3 in my circle of life that I know off, have you guys had the same leak?. And second my choke lever does not stay very well in the choke position it wants to move more towards the run position all by itself. This could be normal and its not an issue im just wondering if you guys 1200s are the same or not?
Thx, Roy.
Roy
1974 Honda 500 four
1978 GS750E
1965 Triumph 500 tiger compitition
1984 Aspencade Gl1200
RoyP is offline
post #2 of 24 (permalink) Old 04-01-2011, 08:35 PM
twhite5262's Avatar
My 84 a spy has no drips knock on wood. By water I guess you mean antifreeze? My choke does want to slowly spring back too but works fine
twhite5262 is offline
post #3 of 24 (permalink) Old 04-01-2011, 09:01 PM
rideandslidejim's Avatar
No leaks on mine.Choke is a bit firm to push, but fine otherwise.
Jim
Body and Bike in southern Georgia,heart and head back in the Del/Mar/Va.
Jim
"Member of lousy spellers of America"
rideandslidejim is offline
post #4 of 24 (permalink) Old 04-01-2011, 11:01 PM
s_lapid's Avatar
Don't know about the coolant drip, but with the choke I solved the problem very simply:
I cut a 2.5 cm. piece of thick rubber hose and cut it open creating a kind of open spacer.
Before starting the bike I pull out the choke and put the spacer on the protruding choke cable preventing it from crawling back. This way I can decide when to remove it. You can drill a small hole the end of the rubber spacer and tie it with a fine string to the handle bar so you won't lose it while not in use.
s_lapid is offline
post #5 of 24 (permalink) Old 04-01-2011, 11:31 PM
CrystalPistol's Avatar
Coolant could be from hose, etc following to lowest point before falling off ..... or if from where I think you mean, the sign that a new water pump may be in the future.
It's not a hard job, just not a real cheap one. In bike, a few gaskets, a new water pump, and silicate free AF/coolant mixture.
...(Candy Spectra Red )
CrystalPistol is offline
post #6 of 24 (permalink) Old 04-01-2011, 11:38 PM
Thx, Roy.
Three of you at the same time?
The bad news is that you all need new water pumps.
The good news, maybe you can get a better price for three at a time.
Ken Bergen is online now
post #7 of 24 (permalink) Old 04-01-2011, 11:57 PM
Down
Down's Avatar
Year: 1996
Model: Gl 1500 Aspencade
Send a message via Yahoo to Down
I had a small drip on mine and it turned out to be the overflow hose that ran from the radiator to the reserve tank also the choke on mine does the same thing i usually carry a small pocket knife and when i start it up i wedge it in thr for a while until im ready to ride
Take the long way around!
Down is offline
post #8 of 24 (permalink) Old 04-02-2011, 01:16 AM
jdvorchak's Avatar
With all due respect I have a more simple fix. Just loosen the two Clutch Master Cylinder clamp bolts a turn or two. Push the MC a little closer to the grip pinching the choke lever a little. Tighten up the clamp bolts.
That's what i did on my 85 Aspy and it worked like a charm.
Still not sure what I want to be when I grow up.
I have 2 other bikes. 2001 GL1800 and 2000 HD Dyna FXDX. Can you say MBS?:
jdvorchak is offline
post #9 of 24 (permalink) Old 04-02-2011, 01:58 AM
s_lapid's Avatar
are you sure this can be done on 1100/1200 as well?
I looked again and the choke lever is located on the hanlebar just in front of the speedometer(GL1100), and there is nowhere near something it can be pinched against.
s_lapid is offline
post #10 of 24 (permalink) Old 04-02-2011, 02:54 AM
jdvorchak's Avatar
It won't work on the 1000 and 1100 but he was asking about the 1200. I've had 3 GL1200's and I used that method to control the friction on 2 of them. The 1200 STD is fine but then I've never had the controls off the bars.
GL1200 Sei water pump replaced, but neutral/shift question firefighterrider Goldwing Technical Forum 3 03-09-2012 06:18 PM
Water leak from GL1200 radiator drip line just winging it Goldwing Technical Forum 15 08-02-2010 02:19 PM
gl1100 choke question goatman123 Goldwing Technical Forum 4 05-07-2010 09:52 PM
1200 Choke question zonk3939 Goldwing Technical Forum 3 02-16-2006 08:33 AM
