1500 SE headlight issue - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 04-04-2011, 09:22 PM Thread Starter
Installed replacement aux driving lights. Had bike running, when I made final connection the headlight went out (won't come back on). Checked fuses on block, all good. Am wondering if I may have fried the headlight relay(s).
Any ideas, folks?
The country that forgets it\'s defenders, will itself be forgotten.
Unknown
Rick L is offline
post #2 of 5 (permalink) Old 04-04-2011, 09:43 PM
Oh - THAT guy...
rpeters549's Avatar
Make: 1500
Don't forget to check the obvious- you spiked power and just burned out the bulb filaments, or the plug was not in all the way. (just thoughts from my previous experiences)
Avatar- 1963 Kenskill trailer
rpeters549 is offline
post #3 of 5 (permalink) Old 04-04-2011, 10:09 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Rick
When installing auxiliary driving lights they must be on their own circuit to protect the wings wiring.
Disconnect the wiring for your added lights. Then swap the Hlight relay with another in the panel of the same amperage. Hlight should come on.
Here is a pic. Hlight relay located top left. Mine removed for servicing the connectors.
JD
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #4 of 5 (permalink) Old 04-05-2011, 08:43 AM Thread Starter
I used the same connection previous owner used.....not sure what wire he tapped into for power.
Which wire would be best for these lights?
Unknown
Rick L is offline
post #5 of 5 (permalink) Old 04-06-2011, 01:00 PM Thread Starter
DUUUUHHHHHHHH.....had a blonde moment....or maybe it's ..."retired-itis" found a 5 amp fuse blown that was hard to see under the relays. Problem solved, used a separate circuit for lights....
Unknown
Rick L is offline
89 1500 CB issue bluwing Goldwing Technical Forum 2 06-19-2012 06:46 PM
GL1100 headlight issue CALEBNDAD Goldwing Technical Forum 12 03-27-2012 08:52 PM
HID headlight conversion issue crazzyrman Goldwing Technical Forum 34 03-22-2012 06:29 AM
Headlight issue on 89 GL1500 Tucson5 Goldwing Technical Forum 3 10-28-2011 07:41 PM
Headlight issue - Hi is Lo, Lo is Hi - need advise tallnwise Goldwing Technical Forum 13 02-10-2008 05:19 PM
