Onboard air control fittings, GL1100.... - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 04-10-2011, 11:45 PM Thread Starter
I just picked upa an 1982 Aspencade, I'm giving it a complete once over before I ride it.... it has the onboard air ride pump from the factory mounted on the false tank... one of the POs un hooked the front forks from the system and plugged the line from the control unit with a bolt, the back was still hooked up, but the pump didn't work. It was just a bad connection... now I want to put it all back together, but I need the fitting that goes from the hose on the control unit to the front fork. The PO put an air nossel in the fork.... See pic... I need the fitting (I don' know what it looks like) that connects the line from the control unit to the fork.... any ideas where I can get one???
Thanks....
Latitude42 is offline
post #2 of 2 (permalink) Old 04-11-2011, 07:58 AM
Lost on this *****
Winger77's Avatar
Model: 1997 Aspy
Send a message via AIM to Winger77
I don't know enough about the 1100's,,,,,, but this might help you out,,,,,,,,,,,
http://partsfinder.onlinemicrofiche....p;A=9&B=74
The things I liked,,,,I\'ve tried em twice!
You have to be a little Crazy,,,,,, or else you\'ll go Insane.
Winger77 is offline
Teflon Tape on Air fittings? Xtracho Goldwing Technical Forum 10 10-28-2010 07:56 AM
GL1100 Rear Shock Air Valves Located Where? (no onboard pump) goldie4ever Goldwing Technical Forum 2 09-12-2009 05:59 AM
Air line fittings Al Himer Goldwing Technical Forum 6 06-30-2009 08:02 AM
81 GL1100 Onboard Air Compressor Installation Ohwell24 Goldwing Technical Forum 6 12-18-2008 11:37 AM
Air hose fittings slevans168 Goldwing Technical Forum 4 11-12-2007 07:22 PM
