85 1200 goldwing - Steve Saunders Goldwing Forums
post #1 of 23 (permalink) Old 04-20-2011, 10:27 AM Thread Starter
mort952's Avatar
When putting bik on center stand tire does not come off the ground can you help with this Thank you
You are never lost when you have Gas
mort952 is offline
post #2 of 23 (permalink) Old 04-20-2011, 10:39 AM
Do you mean that when the bike is on the center stand that the rear wheel touches the ground with the front wheel also touching the ground? If so, then may be too much air in the rear shocks.
If the rear wheel touches and the front does not, then block the swing-arm up so that it does not touchif you need to service something at the rear.
CaptainMidnight85 is offline
post #3 of 23 (permalink) Old 04-20-2011, 10:44 AM Thread Starter
mort952's Avatar
Ok I wiil check this today Thank You
mort952 is offline
post #4 of 23 (permalink) Old 04-20-2011, 11:43 AM Thread Starter
mort952's Avatar
checked at 28lbs The person i got the bike from was a large man may have put taller tires on
mort952 is offline
post #5 of 23 (permalink) Old 04-20-2011, 12:49 PM
Impersonating a mechanic
PAPete's Avatar
Year: 1982 & 1985
28 psi is not a lot. They recommend no higher than 57 lbs, if memory serves (fat chance!)
Could this be a problem with the swing arm? Someone with experience willhopefully check in here.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is online now
post #6 of 23 (permalink) Old 04-20-2011, 12:53 PM Thread Starter
mort952's Avatar
Thank you will try to check it out
mort952 is offline
post #7 of 23 (permalink) Old 04-21-2011, 10:17 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
have an aspy and an sei
aspy has wheel on ground,metzler tires progressive shocks
sei has wheel off ground,e2's with stock shocks
progressive shocks are 1/2" longer than stock aspy oem's,beleive its that and maybe a slight difference in tire diameter with the metz's that does it
neoracer is offline
post #8 of 23 (permalink) Old 04-21-2011, 10:50 PM
Shooter's Avatar
Model: 2006 ST 1300
Belated welcome, my 86-I is the same way. It drags on the ground, but can be turned. You may have a little wear at the swing-arm pivot. Or, as you say the tire may be a bit taller than the OEM Dunlop...
1986 Interstate, 2006 ST 1300
Shooter is offline
post #9 of 23 (permalink) Old 04-22-2011, 12:27 AM
Make sure when you air up the rear shocks to check the pressure WHILE the bike is on the center stand. 45 lbs. pressure while the bike is on the stand is about right for one up riding.
escogold is offline
post #10 of 23 (permalink) Old 04-22-2011, 06:49 AM Thread Starter
mort952's Avatar
Thank for the info i am still lookin it over. New to the Goldwing world. Went from Yamaha to Goldwing what a ride loving it
mort952 is offline
goldwing 86 1200 semper7 Goldwing Technical Forum 9 11-03-2011 11:09 AM
1200 goldwing sandman jim General Motorcycle Discussion Forum 30 04-26-2009 09:40 PM
1200 goldwing gumby Goldwing Technical Forum 2 03-25-2008 04:35 PM
1200 goldwing basstracker Goldwing Technical Forum 13 12-15-2007 09:20 PM
1200 goldwing hp? carson General Motorcycle Discussion Forum 6 10-12-2006 07:59 AM
