1983 brake light/front lever - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 04-21-2011, 04:05 PM Thread Starter
Model: 1983 GL1100 Standard
So I was going over the ride for the annual safety inspection, and I notice that the brake light goes on when the brake pedal is depressed, but NOT when the front brake lever is.. Looking at the wiring diagram, and seeing there are two wires that plug in the rear of the front lever, it appears this is supposed to light the brake light? Fuses look fine, and I am relatively sure I can get my sticker but still will like to get it working if it supposed to. Has anyone encountered this..? THX
2002 Victory Classic Cruiser
DaveTV is offline
post #2 of 6 (permalink) Old 04-21-2011, 04:51 PM
Senior Something
ebanjo's Avatar
Year: 1979
Model: GL 1000
There is a brake switch in the hand lever, it has two wires going to it and one screw holding it in. It may be bad.
Happy Trails
My pic's
ebanjo is offline
post #3 of 6 (permalink) Old 04-21-2011, 08:16 PM
GLGREZMONKI's Avatar
Location: Bedford (Halifax Regional Municipality), Nova Scotia, Canada
Model: SE 1500
The front brake uses a small micro switch to activate the brake light. Those switches can be taken apart and cleaned up and will usually start working. There is only one screw holding it in place. If cleaning does not work they are relatively cheap to purchase at the Dealer.......
GLGREZMONKI is offline
post #4 of 6 (permalink) Old 04-22-2011, 08:59 AM Thread Starter
Cleaned it up, it works like buttah!
DaveTV is offline
post #5 of 6 (permalink) Old 04-23-2011, 11:39 PM
Model: 1983 Goldwing Interstate
Same exact thing happened with me a couple weeks ago during my NY State inspection. Did you actually open up the switch or just clean it and the little plunger? It seems to work just doing that. It doesn't look like it would come apart.
johnny42 is offline
post #6 of 6 (permalink) Old 04-24-2011, 09:09 AM Thread Starter
I did remove it it and spray around the plunger but didn't open it up, I also sprayed and toothbrushed the electrical contacts with WD-40, both the male and female ends and that seems to have done the trick
DaveTV is offline
No brake pressure on front left brake lever.. chesterwgunn Goldwing Technical Forum 9 08-28-2008 08:23 AM
Brake Light won't come on with front brake lever GL1100 DarinS Goldwing Technical Forum 7 12-27-2007 08:11 PM
No turn signals,no brake light w/ front brake lever? S.C Goldwing Technical Forum 5 09-27-2007 05:38 PM
Hand lever brake light switch 84wing Goldwing Technical Forum 11 06-16-2007 06:30 AM
Front brake lever does not trigger the brake light.. packy1 Goldwing Technical Forum 2 03-03-2007 09:52 PM
