GL1500 trike build - Steve Saunders Goldwing Forums
post #1 of 28 (permalink) Old 04-22-2011, 10:42 AM Thread Starter
ade747's Avatar
bike striped ready to trike,not made up my mind what axle to opt for,still planing,onwards and upwards.
ade747 is offline
post #2 of 28 (permalink) Old 04-22-2011, 03:01 PM
GLORYRIDER1's Avatar
Hello Ade.
Welcome to the forum. I just finished my trike build.
I went with the champion sidecar kit. I was able to do all the work.
I hope that you have the same good luck with you build.
GLORYRIDER1 is offline
post #3 of 28 (permalink) Old 04-22-2011, 03:28 PM Thread Starter
ade747's Avatar
thanks,is yours independent or live axle,did you keep the air ride?im not sure if i am going to buy a kit or make one up my self.
ade747 is offline
post #4 of 28 (permalink) Old 04-22-2011, 04:41 PM
Here is the picture of the rear end.
It has the OEM adjustable air shock is used in conjunction with (2) new progressive 416 air shocks.
post #5 of 28 (permalink) Old 04-22-2011, 04:45 PM
Oops I send the wrong picture with the last posting
post #6 of 28 (permalink) Old 04-22-2011, 05:10 PM Thread Starter
ade747's Avatar
looks good,is your diff central,i see by the first pic your swimg arm has been removerd,is this still the case with axle in place?
ade747 is offline
post #7 of 28 (permalink) Old 04-23-2011, 01:08 PM
It has the swing arm also.
File Type: jpg Side view of the rear end with the swing arm.jpg (142.3 KB, 194 views)
post #8 of 28 (permalink) Old 04-27-2011, 10:58 AM Thread Starter
ade747's Avatar
took side stand of,now light on dash stays on,any idears on how to deal with this,thanks
ade747 is offline
post #9 of 28 (permalink) Old 04-27-2011, 02:43 PM
Hello Ade747.
If you wish to eliminate the side stand and not worry about the switch opening up and shutting down. Just take the green/white and green wire and put them together.
That what I had to do and the light did not come on.
Then just tuck the wires up inside the side cover.
File Type: jpg Rear end with Mufflers no Body yet.jpg (169.1 KB, 152 views)
post #10 of 28 (permalink) Old 07-24-2011, 01:07 AM Thread Starter
ade747's Avatar
here some pics so far,still lots to be done and no time to do it in
ade747 is offline
GL1500 trike build ade747 Goldwing Technical Forum 27 03-31-2013 03:43 PM
Honda GL1500 Se Trike Build skip20 Trikes, Trailers and Sidecars 921 10-15-2012 09:11 AM
GL1500 trike build ade747 Goldwing Technical Forum 47 10-21-2011 04:31 PM
Dan's GL1500 Triwing Trike Build Mcdanl Goldwing Technical Forum 103 09-04-2011 04:54 PM
GL1500 ASP Trike Build Project Mcdanl General Motorcycle Discussion Forum 5 01-16-2011 01:12 AM
