GL1000 1976 long handles - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 04-24-2011, 03:06 AM Thread Starter
mygoggie's Avatar
I want to have a new set of 1976 handlebars bend from stainless steel. No, these are not to be found in South Africa at a breaker.
Can someone please measure a set and let me know what the dimensions are? Please include the OD and ID of pipe section as well as ID of the wiring holes.
I think the best would be to lay it flat and then measure from the centerline to each corner and end. If you are good with CAD a e-drawing will be great!
- To heal the soul is to start a new journey -
mygoggie is offline
post #2 of 7 (permalink) Old 04-24-2011, 08:00 AM
Big Cahuna's Avatar
If your having them bent differently from the stock bars, one problem I see is the clutch and throttle cables not working properly.There's not much in the way of readily available different length cables made for an old wing.That also would have to be custom made at additional cost.,,
Bikes Ive owned, \'69 Norton,\'48 Harley panhead, \'71 Bsa, \'76 gl1000,\'93 Harley ultra,\'03 Harley ultra,\'05 Sportster, \'82 GW 1100.\'96 Police road king very used. "I tried thinking once, but nothing happened" .,,,
Big Cahuna is offline
post #3 of 7 (permalink) Old 04-24-2011, 08:09 AM Thread Starter
mygoggie's Avatar
All cables and hoses are to be replaced in any case, so that is not a problem. I cannot do that before I have the handles made.
mygoggie is offline
post #4 of 7 (permalink) Old 04-24-2011, 08:16 AM
RB
RB's Avatar
Send a message via AIM to RB
I have several in my parts pile but 78 or 79's no wire hole at the center..I'll measure and post the od and id..the hole at the center on the 76's was oval about 3/4" long and as wide as could w/o going up the side of the bar so it couldn't be seen when mounted. be back soon with specs.
od 22.44 mm
id 16.18 mm
And end to end = 46 inches. I took a string and laid it along the bar end to end and then measure the string straight out..maybe off a bit but very close.
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #5 of 7 (permalink) Old 04-29-2011, 02:26 AM Thread Starter
mygoggie's Avatar
Thanks @RB!
mygoggie is offline
post #6 of 7 (permalink) Old 04-30-2011, 07:32 AM
Happy Goldwinger
Anim8or Earl's Avatar
Model: GL1000, 1978 Black.
Stainless steel for long bars could be a bad idea. Stainless is more brittle than mild steel and the stresses from road bumps might make them crack or break. Most custom shops won't make long bars from stainless now.
Earl
Anim8or Earl is offline
post #7 of 7 (permalink) Old 04-30-2011, 08:48 AM Thread Starter
mygoggie's Avatar
I am using SS316, which is more ductile than mild steel, so there should be no problems.
mygoggie is offline
Is a 1976 GL1000 interchangeable (all parts) with a 1978 GL1000? ryster Goldwing Technical Forum 11 12-16-2010 11:11 AM
1976 Gl1000 Mr T General Motorcycle Discussion Forum 1 07-20-2009 05:29 PM
1976 GL1000 presariodell General Motorcycle Discussion Forum 4 07-04-2008 04:10 PM
1976 GL1000 For Sale/Wanted Forum 0 10-19-2005 04:19 PM
1976 GL1000 Goldwing Technical Forum 22 12-28-2004 12:02 PM
