Noisy gear sound - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 05-03-2011, 01:21 AM Thread Starter
jurasic's Avatar
Hi there all, Jurasic here from the land of Oz. I have a 96 1500cc Aspy which under acceleration gives out a whine which is constant through the gears... 1st to OD.
Its not in the motor because if I clutch it while coasting the noise goes. It sounds to me like its coming from the front of the bike, or to one side of the motor. Up over 120 klms hr you cant hear it. What do yas all think it may be...Helpppp!!!
Thanks gang for a great site
jurasic is offline
post #2 of 9 (permalink) Old 05-03-2011, 02:01 AM
notodd's Avatar
Send a message via MSN to notodd
well could be clutch going but my guess would be your something with the drive shaft. someone will be alone to help you, Im not an expert with 1500s. Welcome to the best goldwing forum ever.
82 gl 1100 Ok not naked anymore. Have pics, Now working on paint.
My name is Wayne
notodd is offline
post #3 of 9 (permalink) Old 05-03-2011, 04:07 AM Thread Starter
jurasic's Avatar
I also have a 1200 Aspy which does the exact same thing, must be contageous between bikes. How much backlash should there be at the rear tyre.
jurasic is offline
post #4 of 9 (permalink) Old 05-03-2011, 04:32 AM
BRowan's Avatar
Gearshaft bearings, they would stop moving when you pull the clutch on the move. Everything else would still be moving, like drive shaft, wheels, engine.
Brian Rowan
BRowan is offline
post #5 of 9 (permalink) Old 05-03-2011, 01:45 PM
Senior Moment Member
Hanko's Avatar
Model: 2004 GL1800A
Hi Jurasic, welcome to the site!!!! Hang around a little bit and the 1500 experts will be along to give you a hand with your problem.
Again...Welcome to the best motorcycle site on the web!!
Henry
2004 GL1800A Dark Red
Yes that is ice on the fender!!!
Darksider # 902
Hanko is offline
post #6 of 9 (permalink) Old 05-03-2011, 03:02 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Is this your 1500 when ompared to another? or just "Both your wings"?
Reason I ask is that the tranny (for all the love it gets) is really pretty loud on its own. Gears are moslty square cut and to generate some noise -- of course loaded gears are louder gears in all manners.
If this is "all of your Goldwings" (as your sample), then I'd offer that you may want to experiment with an oil change and opt for a higher viscosity, or oil that will stick onto gears a bit better than what you're runnig now.
Take a moment to peek at photos in this tranny thread https://www.goldwingfacts.com/1500gearsfix.htm (BTW, the author has some serious stones about him) -- but do look at the gears -- flat on flat... nothing you'd find in a nice quiet automobile, and they do produce some noise compared to lighter bikes...
if this is your 1500 compared to another 1500, the oil change may be a good first step, btu after that... you'll be hunting a bit more.
satan is offline
post #7 of 9 (permalink) Old 05-04-2011, 05:04 AM Thread Starter
jurasic's Avatar
Okay I am doing a filter and oil change this weekend, I might try some 10W-50W oil. I usually use Valvoline 10W - 40W in the 1200, but have just picked up the 1500 two weeks ago.
Great bikes my friends, thanks for your help as I live out in the desert of Oz and we dont have access to the gear you guys do in the USA. But its all about the ride, just love it (bloody kangaroos not good) lol.
jurasic is offline
post #8 of 9 (permalink) Old 05-04-2011, 05:07 AM Thread Starter
jurasic's Avatar
Here is a pic of my old 85 Goldy 1200 ... goes like a rocket
Cheers to all for now
jurasic is offline
post #9 of 9 (permalink) Old 05-04-2011, 01:35 PM
chorvath's Avatar
Send a message via AIM to chorvath Send a message via MSN to chorvath
Whiny transmissions are pretty much the norm for Goldwings. I always enjoyed going to rallys, like the deceased Honda Homecoming, and listening to all the whiny noises coming from our babys
chorvath is offline
GL1500 Noisy 4th gear Lindeman Goldwing Technical Forum 11 03-17-2012 08:27 AM
'86 1200 I chirping sound in 5th gear stevefl Goldwing Technical Forum 6 01-21-2010 12:07 PM
Noisy speedometer DocWagon Goldwing Technical Forum 8 04-12-2009 01:59 PM
5th gear is noisy, 1-4 are quiet and strong Bro D Goldwing Technical Forum 11 10-09-2008 01:13 PM
Noisy Gears mark Goldwing Technical Forum 6 04-24-2005 08:55 AM
