1978 GL1000 fuse box? - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 05-06-2011, 06:20 AM Thread Starter
Send a message via MSN to MurrayF
Hello
while waiting for my new harness to come i have started poking around
the PO has done some weird wiring but
i cant see any fuses anywhere except the main one
my manual shows it to be under the left side tank cover ????
not there
can anyone tell me if this is so?
Thanks
murray
1982 CM250
1980 CX500
1978 Gl1000
1976 GL1000
1973 CB750
1970 CB200
1970 CL450
MurrayF is offline
post #2 of 5 (permalink) Old 05-06-2011, 06:24 AM
GregForesi's Avatar
It's up under the shelter gauge cluster. Pull out the plastic glove box and you'll see a rubber strap that holds the box in place (right under the shelter cover latch). They moved it for 78-79.
2006 GL1800 (Brutus Maximus)
1978 GL1000 (White Trash)
GregForesi is offline
post #3 of 5 (permalink) Old 05-06-2011, 06:55 AM Thread Starter
Ok
so I found the fuse box with a flashlight got the fuse that was blown traced
replaced it and now have correct power to the rear tail light
removed the bypass from the acc box that the po had put in
when i start the bike the rear signals now flash but the fronts dont
also my running voltage (headlight removed) with the old battery is around
13.75- 14.5 after a bit but the recifier(near the battery)? is getting real hot
i am waiting for a new harness before i do any major repairs as the one i have
is chafed been fixed by [email protected]#$% and has a two foot splice job for each stator
wire funny he did the stator connector bypass but not the rectifier?
the thing i am wondering is do i need a rectifier or is it getting hot from
bad 3 wire plug and a crappy old battery the battery will start the bike but has a bad
cell so only 10.5 volts at rest i will pick one up tonight but can that cause the rectiifer
to over heat or do i have some other problem i will have to wait for parts for?
thanks for all your help.
murrray
1982 CM250
1980 CX500
1978 Gl1000
1976 GL1000
1973 CB750
1970 CB200
1970 CL450
MurrayF is offline
post #4 of 5 (permalink) Old 05-06-2011, 07:31 PM
Well, in my opinion, U DEFINITELY need to replace the battery ASAP. Running one with a battery with a dead cell like that WILL burn out the rectifier and the stator, as its constantly trying to build the battery back up and it can't. Replacing the battery should help. I can understand completely about the wiring, my 75 model is in similar shape....a previous owner (or more than one) had butchered the wiring so badly that even though I'm an automotive tech with 30 years experience, I haven't been able to trace down all the "bad" spots in the wiring....hence the reason I'm looking for another harness to use to either replace this one, or to modify as a newer and improved harness to replace this one with. Hope this helps.
Robert L. Gray Jr. NREMT-P
**** happens, and I am a happenin\' kind of guy!
domscorpiorlg is offline
post #5 of 5 (permalink) Old 05-07-2011, 04:11 AM Thread Starter
Well
i charged the battery off line now holds charge at 12 volts and passes load test
repaired the fuse box clip installed a new fuse removed the PO bypass
soldered that and the rectifier connection. installed a electronic tridon flasher
cleaned the handelbar blinker switch and now all is well,
Thanks so much for all the pointers i will still install a the new harness when it gets here
next week as the old one is chafed and exposed in many places and just plain scary.
now if i can only find a headlight ring that matches one of the buckets i have
i can go test ride it for a few hundred miles then strip and paint.
Murray
1982 CM250
1980 CX500
1978 Gl1000
1976 GL1000
1973 CB750
1970 CB200
1970 CL450
MurrayF is offline
1978 GL1000 Fuse box rubber strap kjdiz For Sale/Wanted Forum 3 08-09-2012 09:10 PM
Fuse box cornbreaddaddy For Sale/Wanted Forum 10 04-25-2011 07:38 AM
fuse box mmonsterbuck Goldwing Technical Forum 3 02-20-2009 07:48 PM
fuse box 2 mmonsterbuck Goldwing Technical Forum 2 02-20-2009 07:02 AM
GL1000 1978, Main fuse melting ran429 Goldwing Technical Forum 4 02-18-2005 09:59 AM
