96 GL 1500 SE - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 05-24-2011, 12:11 PM Thread Starter
jodell2's Avatar
when I turn my key tostart my bike the headlight does not automaticlly come on (sometimes that is). After it is started the light will eventually come on, say 3 to 4 minutes later. Any ideas where to start looking for the problem? Any help would be greatly appreciated.
John L. O\'Dell Jr.
jodell2 is offline
post #2 of 4 (permalink) Old 05-24-2011, 12:18 PM
SaiBeer's Avatar
jodell2
The reason mine did that was because I had a dirty starter button on the right handlebar. I took the button apart and cleaned it and the lights worked great again. Somew say just spray it with contact cleaner, but I figured that was a temproary fix. If you wanted to test the therory you could start there though.
Not the Guru on this for sure - I am sure someone will be along shortly with the know-how thou.
Best to keep the rubber side down and the bike between you and the pavement
SaiBeer is offline
post #3 of 4 (permalink) Old 05-24-2011, 02:17 PM
pwhoever's Avatar
You may also want to check the low beam relay. Mine went bad and would occasionally not come on as well.
Mike K.
97 Aspencade - Pearl White
Darkside Rear Tire- Austone 175R16
Double Darkside Front-Battl-Ax BT-45 130/70-18
2014 starting mileage- 60106
Darkside #1659
pwhoever is offline
post #4 of 4 (permalink) Old 05-24-2011, 04:51 PM
SabreJoe's Avatar
Switch needed cleaning on mine.
SabreJoe is offline
newbie's 1500 mile trip on a 1500 - need info wa2ddl Goldwing Technical Forum 65 02-25-2012 06:52 AM
converting non reverse 1500 to se 1500 cycleman0622 Goldwing Technical Forum 3 10-31-2011 12:19 PM
InstaTrike Kit for 1500 in Florida On CL $1500.00 jimbo1145 For Sale/Wanted Forum 2 03-09-2009 11:28 PM
UK spec 1500 goldwings and imported 1500 wings peakey123 Goldwing Technical Forum 3 09-16-2008 04:37 PM
