Clutch master Cylinder, GL1200 - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 06-02-2011, 12:01 PM Thread Starter
midnightrider1's Avatar
My old 85 Gold Wing is beating me up. LOL Well my site glass went bad on my MC on the clutch side. So I file a dime down JB weld it in good and tight no leaks at all. So my rubber top needed replacing for the cap done that. I also notice when I cleaned MC it look like a dirt build up in it. So clean all that and bead the MC. So now I go to bleed the whole system using clean dot 4 fluid. Squeeze the heck out of the clutch then us a tie down to hold the handle open the bleeder that's drain into a cup filled with water I see some air bubbles once. I do close the bleeder valve before letting the lever loose. I have done this a few times now I think I am getting blow by in the MC because the fluid is turning brown again when it should be pushing the fluid threw if it works like any other MC as I have work on over the years. That's what I think it is being my fluid is getting dirty.
What do you all think. First Gold Wing been around the block once. It just haunts me I fix one thing and something else. LOL Life and it keeps going on.
Frank
midnightrider1 is offline
post #2 of 14 (permalink) Old 06-02-2011, 12:05 PM
magneto mike's Avatar
Leave the bleed nipple open for a while Frank, tie the lever to the grip and let the old fluid drain out. Keep topping the MC up so it don't let more air into the line.
magneto mike is offline
post #3 of 14 (permalink) Old 06-02-2011, 12:09 PM Thread Starter
Hello Mike
I sure will give that a try cause I can see fluid running when I open the bleeder valve. Just as soon as I get cool off. The heat and humidity in SW, Mo is a killer on me. LOL
Thank You
Frank
post #4 of 14 (permalink) Old 06-02-2011, 02:11 PM Thread Starter
Hello Mike
I did just what you said but when tied the lever down and open the bleeder it wouldn't bleed. But when I release the leaver it started gravity bleeding. I ran about 3/4 of 32 oz can fluid threw it. Close the bleeder top off the MC then fire the bike up.
Let it warn a bit It went in gear but kind like jump into gear gave it a bit of gas to see if it would engage and it did when the lever was about haft way out or more It wanted to go. I got to air the rear tire up its flat to take it around the block to see what happens. Don't want to get tires till I know this thing gonna work. Tires on my last of the list for now. I'm in a small town everything 50 miles or better away. LOL
Man its hot now I'm done till it cools down
Frank
post #5 of 14 (permalink) Old 06-02-2011, 03:07 PM
Clutch bleeds backwards. Opposite of a brake.
post #6 of 14 (permalink) Old 06-02-2011, 03:09 PM
What you are experiencing is so common. The problem is the master cylinder needs to be the highest spot. It is not. The banjo fitting is and the air gets trapped there with no way out. Put the bike on the center stand and even lean it to the right as much as you can safely. Now turn the handlebars to the far right and bleed as normal. Now the master is the highest point and it will work for you. Good luck.
redwing52 is offline
post #7 of 14 (permalink) Old 06-02-2011, 03:59 PM
I see you edited your post Dennis.
I'm just wondering what manual you were reading.
This is from the Honda Manual.
Air Bleeding
NOTE Check the fluid often while bleeding the
clutch to keep air from being pumped into the system.
Squeeze the clutch lever, open the bleeder valve 1/2 turn
while applying pressure on the lever, then close the
valve.
Release the clutch lever slowly and wait several seconds
after it reaches the end of it's travel.
Repeat the above steps until bubbles cease to appear in
the fluid at the end of the hose.
Tighten the bleed valve.
Fill the reservoir to the upper level.
It looks like the same as bleeding brakes to me.
And what redwing52 said is true, the outlet banjo joint is the high point of the system and will trap air if it's not brought level or bled separately.
Ken Bergen is online now
post #8 of 14 (permalink) Old 06-02-2011, 04:41 PM Thread Starter
Hello Redwing
hope my ISP keep running. LOL trouble with today as well.
So by being it wants to jump into gear instead of going into gear easy means I still some air in the line. No I didn't have it on the center stand when I bleed the Clutch MC. I have a small cement pad I poured just to do that on being I don't have a garage it didn't off the center stand to well last time. I have a fix for that I think. LOL
So get it on the center stand and get the MC to the highest point that can be achieve and bleed the clutch with the lever right. I tried that melted but not on the center stand.
It kind of jumps into 1st gear when applying the clutch and I can take it all the way gears sitting still. Only jumps when putting onto 1st. I also can let the clutch out and it grabs hold about haft way out I thought it was suppose to grab around that area.
I am new at all this just and old guy trying to get some air. hey thanks for all the help.
Center stand OK going up is no problem lol.
Frank
post #9 of 14 (permalink) Old 06-02-2011, 05:33 PM
midnightrider1 wrote:
Hello Redwing
Frank
The jump and clunk when putting it into gear is normal as the spinning transmission gears and clutch plates come to a sudden halt.
For the lever engagement position make sure the lever pusher bushing is in good shape and for the air trapped in the banjo joint after bleeding on the side stand just stand it upright with the bars to the right and pump the lever. Any trapped air will be flushed back into the reservoir.
post #10 of 14 (permalink) Old 06-02-2011, 06:59 PM Thread Starter
____________________
Advise given here is free and comes with no warranty "Caveat emptor".
Ken
Hello Ken.
Sounds like the thing to do is stand it upright lean it to the right and pump the clutch and tap the MC. I think I got the MC done but I am gonna use your advice and do that. I have had a few bikes never a Gold Wing never no hydraulic clutch I thought I knew my way around hydraulics I guess that don't apply to Gold Wings cause the the MC is pointing upwards and you need it to be as level as can be and a little beyond I take it no problem I will give that a try. I was wondering about the jump and clunk like when putting in gear them sounds scare me. LOL Glad you said that's normal
Wish my internet was normal today.
1984 GL1200 clutch master cylinder robcath Goldwing Technical Forum 27 10-01-2012 09:45 AM
GL1200 Clutch Master Cylinder hondavidson Goldwing Technical Forum 4 11-13-2011 12:23 PM
GL1200 Clutch Master cylinder svaughn01 Goldwing Technical Forum 3 04-22-2011 05:48 PM
GL1200 Clutch or Master Cylinder mongo26.2 Goldwing Technical Forum 10 09-27-2010 09:25 PM
Changed 85 gl1200 clutch Master Cylinder kernal70 Goldwing Technical Forum 5 04-16-2009 08:48 PM
