Front master cylinder GL1100 - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 06-09-2011, 11:27 AM Thread Starter
CHELMBOLD's Avatar
My front master cylinder started leaking fluid which is running down the hand grip. If I take off the lid does the reservoir come off the base. I think it is leaking from under the reservoir. This all started after I was parked in the 90 degree heat one day.
CHELMBOLD is offline
post #2 of 3 (permalink) Old 06-09-2011, 01:32 PM
brianinmaine's Avatar
Year: 1980, 1987
Make: Goldwing
Model: 1980 Standard, 1987 Aspencade
Well worth doing.
Brian Trauger
1980 Standard : Pacifico fairing : Vetter trunk.
1987 Aspencade : Fully dressed.
brianinmaine is offline
post #3 of 3 (permalink) Old 06-09-2011, 01:50 PM
Mr Magic Fingers's Avatar
Hey Chelmbold,
Under the plastic of your reservoir there is an o-ring that seals the plastic of the reservoir to the metal. Your either have a bad o-ring or cracked plastic.
Although you "can" delicately remove the fluid out of the reservoir and then removed the reservoir itself and do a repair, but if you have not done your brakes in a while, you might as well clean the whole master cylinder. Just make sure that the tiny little hole in the MC does not get pluged.
Brian points to a very good article.
Tim.
____
Please visit
Mr Magic Fingers is offline
GL1100, help with front master cylinder firebrick Goldwing Technical Forum 12 12-29-2011 09:03 AM
front master brake cylinder '81 GL1100 JamesGang Goldwing Technical Forum 11 07-01-2010 02:32 PM
GL1100 '82 vs '83 front master cylinder. chilidawg Goldwing Technical Forum 5 05-20-2009 06:12 AM
Front master cylinder 82' GL1100 82winger Goldwing Technical Forum 9 07-29-2008 04:35 PM
front master cylinder GL1100 I johnorr Goldwing Technical Forum 8 06-10-2008 08:07 PM
