GL1200 audio question - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 06-20-2011, 11:45 AM Thread Starter
jasonpumper's Avatar
Hi everyone, just got my bike home yesterday, yay, and have some questions. From what I've read the interstate model never had the audio package, but could be added on, so I guess mine was added. The radio works, and the auto volume seems to work. The cb powers up but the display works intermittently. Between the cb and auto volume there is a switch and a knob and I'm not sure what either are for, any ideas? Also is there any way to test the cb and intercom without having the helmets? One more thing is there are 2 five pin connectors coming oit of the left side fairing and also the one in back for passenger. Shouldn't there only be one front and one rear? All wiring looks to be factory like so I don't know, any help is welcome! Jason.
jasonpumper is offline
post #2 of 10 (permalink) Old 06-20-2011, 12:13 PM Thread Starter
My bad, on the front connectors, one is a 5 and the other is a 7, still not sure why there are 2?
post #3 of 10 (permalink) Old 06-20-2011, 12:27 PM Thread Starter
Here is a pic of the switch and knob. If i flip the swith up the radio has no sound, down it does? knob seems to make no difference.
post #4 of 10 (permalink) Old 06-20-2011, 12:45 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
that's not a honda setup except for the avc unit,i'd suggest you contact the PO to answer that
any idea whose cb unit that is?
neoracer is offline
post #5 of 10 (permalink) Old 06-20-2011, 01:00 PM Thread Starter
it says j&m on it. The previous owner wasnt sure why there were 2 connectors up front.
post #6 of 10 (permalink) Old 06-20-2011, 01:06 PM
jwhitmore44's Avatar
Sounds like it depends on which cords you have. Some of the other makes of bikes and intercom systems use a 7 pin cord and the Wings use a 5 pin. The new wing may use a 7 pin, not sure. Some CB's used a 5 pin mic instead of a 4 so the 5 pin could be for an external mic.
Turn your squelch down until you get noise and then play with that switch and see if you get sound through your speakers. If so the extra knob may be for volume control.
03 Honda XR650L
84 GL1200 Aspencade
jwhitmore44 is offline
post #7 of 10 (permalink) Old 06-20-2011, 01:49 PM
neoracer's Avatar
have the J&M install diagrams for those units,pm me an email address
J&M no longer can help,seems the units are older than the help
neoracer is offline
post #8 of 10 (permalink) Old 06-23-2011, 09:13 PM
Paid Site Sponsor
Model: 2015GL,2008GL,2000 Valk
The CB is a J&M MI-2007A. It is a Midland that had all the controls in the mic and main unit is stuffed up in the fairing . The switch controls audio between the headset and the fairing. The y cord with the 2 plugs is so that hand mic could be left plugged in and still use the headset. I originally made this for myself so that when I was off the bike I could easily reply on the CB. Probably only made 100 or so of these. Forgot to mention knob is for talk-back, secondary intercom, so both could hear what the other said on CB. This is the same way OEM worked.
Wayne
Wayne is offline
post #9 of 10 (permalink) Old 06-24-2011, 10:34 AM Thread Starter
Thanks a bunch Wayne, and Neo, never would have known.
post #10 of 10 (permalink) Old 06-26-2011, 09:28 AM Thread Starter
Ok, got everything working except the display for the channels on the cb. Can someone send me the schematics for this system or have a suggestion on how to repair, thanks again, Jason.
'93 GL1500A audio question............ groutby Goldwing Technical Forum 4 03-24-2012 01:41 PM
Audio Question about adding subwoofers. GL1500 pwhoever General Motorcycle Discussion Forum 11 11-03-2011 01:14 PM
Question for the audio pro's rvtechA1 Goldwing Technical Forum 12 03-19-2011 12:30 PM
Audio Question Ted N Goldwing Technical Forum 1 12-05-2010 07:16 PM
question for you audio/electronic gurus Tinman General Motorcycle Discussion Forum 1 01-24-2009 11:28 AM
