Ignition switch removal, GL1500 - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 07-05-2011, 02:35 PM Thread Starter
dan3071's Avatar
does anyone know how to get the ingnition switch out of a 1988 gl1500 i just bought one and the dealer says they need numbers off the switch to make a spare key.The one i have is usable but not to make another key thanks
dan3071 is offline
post #2 of 6 (permalink) Old 07-05-2011, 02:49 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
I have not done it, however Per the manual (and my recollection of it):
1) Remove the front housing (eg the Front fairing and dash)
2) Hammer a Chisal into each of the two bolts holding the ignition switch, then usal the chisal to Turn (eg Unscrew) the bolt --The bolts are the "anti-theft" type, hence this unusual method of removal.
3) Replace with new anti-theft bolts... I believe they come with hex-heads, that snap off after reaching the proper torque. Myself, I'd just use normal socket head allen bolts.
I wonder if you could more easily use a Dremal-Cut-Off-Wheel, to grind off the bolt heads, rather than using the chisal?... If so, then probably could remove the switch without having do do much dis-assembly at all.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #3 of 6 (permalink) Old 07-05-2011, 03:52 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Welcome on Dan...
Generally I'll avoid the dealer like the plague fo "spare keys" and head to a reasonable locksmith or other key-shop.
I the smith / shop can cut a useable key for ya (test in all tumblers on both sides), then take the pretty new "spare" to your dealer for a fancy Honda key if ya like.
You can also purchase the blank from the dealer or any of a hundred other places to carry with you to your key-guy (BTDT), so you can have a pretty "Goldwing" key like OEM.
(I'd be tempted to grab the right fairing door -- it's got a matched lock, and it's easier to carry :P)
satan is offline
post #4 of 6 (permalink) Old 07-07-2011, 08:18 PM Thread Starter
dan3071's Avatar
hi and thanks for the glove box tip. I picked up a blank key and had it cut check it with the glove box now i have a spare key thanks
dan3071 is offline
post #5 of 6 (permalink) Old 04-13-2012, 04:55 PM
Hello,
I own a 1998 Goldwing 1500.
I have been having trouble with the ignition.
Seems that I need to turn the key to the on position
and find a sweet spot before the bike will start. It
sometimes cuts off when I hit a bump in the road and
I have to pull over and look for that sweet spot again
to get it started. I purchased the replacement, but now
I found that, it appears, the darn thing is riveted to the
bike. Any help greatly appreciated. How many times have I
heard, "Avoid the Dealer"?
Satrooper is offline
post #6 of 6 (permalink) Old 04-13-2012, 05:42 PM
skip20's Avatar
Read the above removal of ign lock.
GWRRA 78111
PGR 255645
To many projects to finish
skip20 is offline
GL1500 Ignition switch Square Shooter Goldwing Technical Forum 7 07-05-2012 12:05 PM
ignition switch removal without removing fairing gl1500 SmartBiker Goldwing Technical Forum 1 04-27-2012 11:07 AM
GL1500 ignition switch alignment wingsound Goldwing Technical Forum 2 03-26-2012 03:58 PM
Ignition Switch Question GL1500: tobiano Goldwing Technical Forum 4 11-23-2009 12:00 PM
Ignition Switch Removal GL1100 I walt_k Goldwing Technical Forum 9 01-14-2007 07:59 AM
