GL1500: How2 Make Windshield Vent Operate Smoother - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 08-14-2011, 11:04 AM Thread Starter
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
A piece of electrical tape makes the windshield vent operate a whole lot smoother... It reduces the "Indent" that the ball bearing falls into.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #2 of 7 (permalink) Old 08-14-2011, 06:36 PM
BenMilner's Avatar
Thanks Alex, that's a good idea and I think will work on the 1800 too.
BenMilner is offline
post #3 of 7 (permalink) Old 08-15-2011, 04:29 AM
hummer5205's Avatar
Year: 2008
Model: 2008 Gl 1800 P premium Audio
Alex The elctricle tape is good But I would get some Tri-flow I got Mine at a bicycle shop ! I used to use it on my old kaw chain & it worked great ! I use it on locks on my windshield vent & Numbers of things ! I think its better then wd-40 as it has a tendancy to dri things out !Anyway go here www.triflow.com & You can learn more about it !
All good things come to He who waitith if he workith like hell while he waitith !
hummer5205 is offline
post #4 of 7 (permalink) Old 08-15-2011, 04:36 AM
hummer5205's Avatar
Year: 2008
Alex instead go herehttp://www.triflowlubricants.com/
post #5 of 7 (permalink) Old 08-15-2011, 06:15 AM
wingsam41's Avatar
As an electrician I use and have tried a lot of electrical tapes and can tell you that while your fix may work for a while you are risking gumming up the works and making things worse later. First not all electrical tapes are created equal and while I may be wrong yours appears to be a generic brand. Some tapes will simply lose or never have enoughhold while othersmore commonly will leave a black very sticky goo that is very difficult to remove. Exposure to direct sun and heat will make this worse. I haven't tinkered withmy ventas it's new but sounds like lubing as the others have said seems the way to go. When your socket driver's ball bearing rusts and sockets get difficult to install and remove lube is usually the answer. Seems like this may be a similar setup?
wingsam41 is offline
post #6 of 7 (permalink) Old 08-15-2011, 09:04 AM Thread Starter
Well I've been using this "Modification" for several years now, and it works fine... It's a nice "creature comfort".
I like the tape better than a lube, because with the now-smaller-indent, the vent does not offer as much resistance to movement.
My goal is to limit how much stress is placed on the brittle plastic, due to having breakage on an earlier vent.
I void warranties
KJ6QFZ
Dark Side #590
post #7 of 7 (permalink) Old 08-15-2011, 05:23 PM
Zeke66's Avatar
The tape is a good idea, thanks Alex. All you need to do is change it occasionally and it won't get all sticky.
Zeke66 is offline
GL1500 Windshield Vent Question TennX Goldwing Technical Forum 5 09-01-2012 08:31 PM
Windshield vent GL1500, how to install? quikcarl61 Goldwing Technical Forum 1 05-03-2012 01:45 PM
GL1500 Windshield Vent Installation bobcree Goldwing Technical Forum 12 03-21-2012 01:41 PM
GL1500: How2 Make GPS Mount ALEX BERECZKY Goldwing Technical Forum 1 08-14-2011 11:37 AM
Windshield vent from GL1500 into GL1100 AZWinger Reference and FAQ Forum 16 05-23-2005 11:27 PM
