1500 timing belts - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 08-18-2011, 03:40 PM Thread Starter
happer's Avatar
Are there any noticeable symptoms of a timing belt needing to be replaced?
How often shud the antifreeze be changed?
happer is offline
post #2 of 5 (permalink) Old 08-18-2011, 04:16 PM
Jason's Avatar
Timing belts don't give any warning signs when they are due for replacement. They can look fine and break a week later. Coolant is supposed to be replaced every couple of years, but you can get away with longer.
Jason
Jason is offline
post #3 of 5 (permalink) Old 08-18-2011, 07:28 PM Thread Starter
happer's Avatar
Thank u. I was told the belts were replaced 30,000 miles ago. He also said a couple of other things were done which he actually SAW had been done, so had no reason to disbelieve the timing belts weren't done.
I appreciate the reply.
happer is offline
post #4 of 5 (permalink) Old 08-18-2011, 11:17 PM
Oh - THAT guy...
rpeters549's Avatar
Make: 1500
My belts were at 81,000 miles when I changed them, but should have done them a bit sooner probably. They looked fine. I think they were the stock ones. I hit a deer in '05 (about 20k on the bike) which caused a lot of damage, but I do not remember Honda charging me for belts and I KNOW they would not have done them for free. Even if they had, that was still 60k on the belts.
As for coolant, the entire system only hold about a gallon. I like to do it every year, two years at the max especially if it sits. It does not take a lot of scale to reduce cooling ability and changing it is VERY easy, not to mention cheap.
Avatar- 1963 Kenskill trailer
rpeters549 is offline
post #5 of 5 (permalink) Old 08-18-2011, 11:19 PM
Oh - THAT guy...
rpeters549's Avatar
Make: 1500
As for your signature, I find the 1500 the easiest to ride of the wings I have owned. Just do it.
Of course, my massive bulk helps (I am 5'10" and weigh in about 155 pounds)
GL 1500 Timing Belts 6adan Goldwing Technical Forum 3 09-15-2010 02:36 PM
Timing Belts 1500 jdb5c Goldwing Technical Forum 12 11-11-2009 12:11 PM
Timing belts for my 1500 ELKMAN121 Goldwing Technical Forum 5 05-14-2008 12:52 PM
1500 GL Timing Belts mark1247 Goldwing Technical Forum 2 06-17-2005 05:12 PM
TIMING BELTS GL 1500 jukeboxjury123 Goldwing Technical Forum 1 07-29-2004 05:26 PM
