1100 OEM Air Shock Length of Travel - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 10-17-2011, 08:18 AM Thread Starter
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
Hey All,
I did a search here and also tried to look up the length of travel of Progressive 416's but couldn't find the answer.
What is the total travel length of OEM 1100 air shocks?
I'm working on a sidecar that takes a 13" shock. I need to know if the travel length of the 1100'sOEM shock will work with the swingarm on the sidecar. And if there is enough swingarm rotational length to add an electroinic lean to the thing.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #2 of 4 (permalink) Old 10-17-2011, 08:26 AM
redbaron's Avatar
Model: GL-1500
I looked too but I do remember this subject coming up a couple of times in the past on exactly the same subject....Maybe who ever posted that original thread will step in and help you....I know I have seen it.......Wish I could help you more.....
Honorary member Wild Rhinos
redbaron is offline
post #3 of 4 (permalink) Old 10-17-2011, 09:30 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
progressive lists their shocks(416) @ approx 3.35" travel
since its for the sidecar i would think that you might want to use the non-air 412's
http://www.progressivesuspension.com/pdfs/7100-105.pdf
neoracer is offline
post #4 of 4 (permalink) Old 10-17-2011, 10:33 AM Thread Starter
Year: 1982
Model: Interstate
Thanks Neo!
I'm wanting the adjustability of air shocks as the sidecar will carry a wide range ofloads. Anywhere from sidecar + ballast only to several 100's of pounds for car + passenger(s) + cargo.
I'm curious what you think the advantages of a coil-over shock might be?
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
Sure.
Is it hard?
PGR since 2011
GL1500 torn shock boot....stock air shock SmartBiker Goldwing Technical Forum 4 08-25-2011 07:41 AM
1981 1100 Air Shock rb7632 For Sale/Wanted Forum 1 08-15-2009 10:02 PM
82 1100 Aspy Air Shock Pressure Warning Light JHerlihy Goldwing Technical Forum 2 07-08-2007 10:14 AM
What are shock travel limiters used for. Dieseltu Goldwing Technical Forum 2 01-12-2007 11:58 PM
OEM Air shock oil Hobie1 Goldwing Technical Forum 4 10-19-2006 08:45 PM
