93 SE lower cornering light question... - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 01-30-2012, 07:35 PM Thread Starter
mr irrelevant
tmdriverwannabe's Avatar
Model: 2009 GL 1800
I replaced both of the lower bulbs today , they do not turn on, fuses are all good. They do not activate with the turn signal either, and wires coming out of them appear to be stock and unaltered. Assuming the relays are bad here but was actually looking at wiring them up so they are on all the time anyway. Can you tell me which wire to splice into next to the bulb so i can accomplish this? Im going to run the wire to the accessory terminal so it comes on with the key....Thanks!!!!
Mark
Current ride is a 09 gl1800 level 3
Wild Rhinos Iowa Chapter
GWRRA #410601 Chapter A Black Sheep Squadron Asst Chap Directors
IOWA PATRIOT GUARD
Now an honorary Newfie!! We have kissed the Cod, downed the Screech, and shouted "Long may your big jib draw!" so are now members of the Royal Order of Newfoundland Screechers.
tmdriverwannabe is offline
post #2 of 13 (permalink) Old 01-30-2012, 07:59 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
My 99 already had been that way from the factory so it's on this site somewhere
Here is a search results for cornering lights
https://www.goldwingfacts.com/forums/...rnering+lights
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #3 of 13 (permalink) Old 01-30-2012, 08:11 PM Thread Starter
mr irrelevant
Model: 2009 GL 1800
I looked through all that earlier also Stu, but couldnt find which one wire to splice to "at the bulb" and not before the relay if at all possible...Im hoping to do this so if i dont like it at later date can just undo it again...I suppose i could just go ahead and run 2 new wires(+ and -) and solder them in near the light, but didnt know if just running 1 wire up there would activate the lights or not...thanks again...
Mark
IOWA PATRIOT GUARD
post #4 of 13 (permalink) Old 01-30-2012, 08:20 PM
Still Learning
newday777's Avatar
I'm not sure either Mark.
Stu
Previous bikes
post #5 of 13 (permalink) Old 01-30-2012, 08:25 PM
Still Learning
newday777's Avatar
I don't know if you have the stock alternator or not but it would be a good idea to put them on a relayed accessory switch to turn them off in case of alt failure down the road.
That's what the original owner did to mine.
Stu
Previous bikes
post #6 of 13 (permalink) Old 01-30-2012, 08:35 PM Thread Starter
mr irrelevant
Model: 2009 GL 1800
Thanks, If i have to run completely new wiring to them i will do that for sure...
Mark
IOWA PATRIOT GUARD
post #7 of 13 (permalink) Old 01-31-2012, 04:32 AM
SabreJoe's Avatar
The bulb sockets sometimes give trouble. Get a multimeter and check if you have power at the bulb sockets when you hit the turn signals. Check the ground while you are there.
SabreJoe is offline
post #8 of 13 (permalink) Old 01-31-2012, 09:59 AM Thread Starter
mr irrelevant
Model: 2009 GL 1800
Am i correct in that the orange/white or blue/white wires are the positive ones then? and whatever the other wire is will be the ground?
Mark
IOWA PATRIOT GUARD
post #9 of 13 (permalink) Old 01-31-2012, 10:39 AM
Bellboy40's Avatar
Year: 2000 & 1994
Mark, the wire colors you referred to are the wires colors from the turn switch to the relays for the cornering lights. From the relays to the lights the colors are red/blue and red/yellow with green being the ground. I am attaching a wiring sketch from the service manual.
Larry
-- Albert Einstein
Bellboy40 is offline
post #10 of 13 (permalink) Old 01-31-2012, 06:11 PM Thread Starter
mr irrelevant
Model: 2009 GL 1800
If the ground wires check out okay, I was thinking of getting the power from the position lights up above. I wouldnt think that those bulbs would draw too much to overload that circuit, but should i run a wire for each side down to each light, or will it be ok to just run the power off of just one of the position lights for both cornering lights? Or should i run new power from the fuse box to power them? Thanks guys!!!
Mark
IOWA PATRIOT GUARD
Light bulb gl1500se lower corner light whitewingguy Goldwing Technical Forum 6 05-31-2011 01:28 PM
Cornering light question, GL1500 MNSNOWMAN Goldwing Technical Forum 11 05-06-2011 03:17 PM
Hello to all/ and cornering light question samsdad42 Goldwing Technical Forum 5 03-12-2011 08:27 AM
Cornering light Dragoon Goldwing Technical Forum 11 11-04-2008 03:48 AM
GL1500 Accessory Clear Lense Lower Cornering light kit Munds Goldwing General Motorcycle Discussion Forum 6 10-13-2008 07:59 PM
