GL1500 Not Starting - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 03-10-2012, 04:43 PM Thread Starter
Cal
Getting bike ready for riding season. Battery been on tender all winter and checks fully charged and good. Turn on key and neutral light is on. When I hit starter switch hear a click and neutral light goes out. Starter doesn't turn over. Fuses all check Good. What should I check next? I'm suppose to take bike over to fellow riders tomorrow so we can replace fork springs and shocks. Can't if I can't get it to start.
Cal
Cal is offline
post #2 of 13 (permalink) Old 03-10-2012, 04:49 PM
ridgid11's Avatar
Model: gl1200
did you put jumper cables on the starter to see if it would roll over,but someone smarter then me will be along soon....hang in there ,they will get you going.did you do a search ???
1983 honda cb350 (gone)
1987 kz 125 (gone)
2003 polaris 330 4x4 (gone)
2009 1973 nonda cd175 (on the road)
2011 1985 honda goldwing gl1200(on the road)
ridgid11 is offline
post #3 of 13 (permalink) Old 03-10-2012, 05:17 PM
Senior Guru
agnogel's Avatar
sounds like a bad connection on the battery or the ground under the seat
Peter
agnogel is offline
post #4 of 13 (permalink) Old 03-11-2012, 09:46 AM Thread Starter
Cal
Checked all connections. Had seat off, battery out. Checked all the relays and fuses, tapped on solenoid. No Luck. Pushed down street this morning still no fire.
Cal
Cal is offline
post #5 of 13 (permalink) Old 03-11-2012, 10:40 AM
ridgid11's Avatar
Model: gl1200
wow i cant belive only one person replyed,kill switch on?
1987 kz 125 (gone)
ridgid11 is offline
post #6 of 13 (permalink) Old 03-11-2012, 10:46 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
> Try Jumping the battery, from a known good one.
> If that does not work, and given that you currently have the bike all opened up, try this:
1) Remove ALL the fuses and Relays from the Fuse and Relay Boxes on the left side of the bike... Leave installed only the 15 Amp Fuse for the "Tail" (4 up from bottom of left box), 5 Amp Fuse #12 (lower rt of relay box) for "Ignition/Tail", and Relays #3 (Tail) and #8 (Ignition/Cuise)
2) Try starting in Neutral.... If it works, then you've isolated a possible short, outside of the ignition circuit.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #7 of 13 (permalink) Old 03-11-2012, 10:56 AM
> Good point! (I remove mine, so always forget to consider them)
Towards that end, either of the Two kill switches could cause this:
-Engine Kill switch on Handlebar (Often has loose terminal screws inside)
-Side Stand Kill Switch
I void warranties
KJ6QFZ
Dark Side #590
post #8 of 13 (permalink) Old 03-12-2012, 02:31 AM
JOHN OPPS's Avatar
Year: 1998
Model: gl 1500
Iwould try a jump start from another battery sounds like a dead cell in battrey or bad ground.
i love it when a plan comes together?
JOHN OPPS is offline
post #9 of 13 (permalink) Old 03-12-2012, 06:05 AM Thread Starter
Cal
Push started and got running. But still won't start otherwise. Ordered new Solenoid and will pull apart all electrical connections and clean. Tried pulling fuses and relays. Battery tested good - had that tested.
Cal
Cal is offline
post #10 of 13 (permalink) Old 03-12-2012, 08:28 AM
Model: gl1500
Neutral light going out on pressing start can only be one of several things. Bad ground at the battery or frame, or a bad or borderline battery cell. Do as the others suggested and try jump starting from a car battery (car engine OFF). If the Wing starts, you have a bad battery.
broadbent is offline
GL1500 starting raven1300 Goldwing Technical Forum 6 10-09-2011 10:52 PM
GL1500 starting go1500wing Goldwing Technical Forum 4 04-17-2011 04:20 PM
Non Starting GL1500. bob w w Goldwing Technical Forum 3 02-01-2011 04:43 PM
Starting my GL1500 delly Goldwing Technical Forum 25 01-23-2011 09:08 AM
GL1500 starting...... BFS Goldwing Technical Forum 14 07-14-2006 03:50 PM
