Gear Ratio difference 81-82 - Page 2 - Steve Saunders Goldwing Forums
post #11 of 13 (permalink) Old 03-18-2012, 08:50 AM Thread Starter
Rumple's Avatar
Model: 1982 GL1100 Standard
BobbySp, I agree 85 or higher the bikes do get to be a handful past that. Honda did a wonderful job of designing a fairing with "lift". I changing my bike back to the standard it was when it rolled off the showroom floor in 82. Than I'm just going to put a simple windscreen on it. As for Lil Pete, enlighten us with what those other problems may be. Thank you
Rumple is offline
post #12 of 13 (permalink) Old 03-19-2012, 12:39 AM
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
With what you describe; high gas mileage, and low power I would suspect a vacuum leak somewhere. which is creating a substantially lean mixture. I bet if you pay attention you'll notice your fan kicking in a lot.
I would check things like; the clamps on the intake boots make sure they are tight, check the vacuum line for the timing advance make sure one end or the other hasn't come off or that the line has dried out and split. There is a screw in the base of each intake runner make sure they are all there and tight. Make sure the crank case breather tube is secure on both ends. If you don't find anything there then it's time to maybe pull the intakes runners and inspect/replace the o-rings in the bases. Inspect the plenum seals maybe.
But I'm pretty sure yer getting extra air in the system somewhere.
P.G.R. Member ID: 88374
Broke Winger is offline
post #13 of 13 (permalink) Old 03-19-2012, 12:40 AM
Another gear ratio question dan filipi Goldwing Technical Forum 9 10-03-2011 10:39 PM
Gear ratio difference 1982 compared to 1983 GL1100 ryster Goldwing Technical Forum 1 04-13-2011 11:06 PM
Gear ratio Nightrider1 Goldwing Technical Forum 12 11-11-2010 11:22 AM
gear ratio skoto1 Goldwing Technical Forum 16 05-14-2009 11:38 PM
1800 gear ratio kenracer Goldwing Technical Forum 2 09-22-2008 10:26 AM
